DC/DC half-brick power converter module 150Q-24S19A isolated and stabilized 24V to 19V single circuit 150W
Visitor3820
Price$39.55
Maximum input current | 9V input voltage, full load output | -- | -- | 14 | A |
Input impulse voltage (1sec. max) | beyond this range input may cause permanent damage | -0.7 | -- | 50 | VDC |
| Starting voltage | -- | -- | 10 | ||
| Under voltage protect | No load test, full load test will provide overcurrent protection in advance | -- | -- | 9 | |
| Remote control foot (CNT) | Positive logic: CNT suspended or connected to 3.5-15V for startup, connected to 0-1.2V for shutdown | Reference voltage - VIN | |||
| Negative logic: CNT suspended or powered off when connected to 3.5-15V, powered on when connected to 0-1.2V voltage | |||||
Load regulation rate | Nominal input voltage, ranging from 10% to 100% load | -- | ±0.2 | ±0.5 | |
| Temperature drift coefficient | Positive logic: CNT suspended or connected to 3.5-15V for startup, connected to 0-1.2V for shutdown | -0.02 | -- | +0.02 | %/℃ |
| Ripple&Noise | 20M bandwidth, external 470uF or above capacitor test | -- | 150 | 190 | mVp-p |
| Remote compensation of output voltage (Sense) | -- | -- | 5 | % | |
| Over Temperature Protection | The highest temperature on the surface of the metal substrate of the product | 105 | 115 | 125 | ℃ |
| Output overcurrent protection | 8.7 | -- | 11 | A | |
| Short Circuit Protection | Hiccup style, sustainable, self-healing | ||||
| sProject | Working condition | Min. | Typ. | Max. | Unit | |
| Isolation Voltage | Input-output | Test time 1 minute, leakage current less than 3mA | -- | -- | 2100 | VDC |
| Input - Shell | Test time 1 minute, leakage current less than 3mA | -- | -- | 2100 | VDC | |
| Output - Shell | Test time 1 minute, leakage current less than 3mA | -- | -- | 500 | VDC | |
| Switching frequency | -- | 210 | -- | KHz | ||
| mean time between failures | 150 | -- | --- | K hours | ||
