  4. half-brick power module
  5. DC/DC half-brick power converter 150Q-24S24A isolated and stabilized 24V to 24V single circuit 150W
    $39.55
18V input voltage, full load output----14A
----30mA
Input impulse voltage (1sec. max)
beyond this range input may cause permanent damage
-0.7--50VDC
Starting voltage
----10
Under voltage protectNo load test, full load test will provide overcurrent protection in advance----9
Remote control foot (CNT)Positive logic: CNT suspended or connected to 3.5-15V for startup, connected to 0-1.2V for shutdownReference voltage - VIN
Negative logic: CNT suspended or powered off when connected to 3.5-15V, powered on when connected to 0-1.2V voltage
--±0.2±0.5
Load regulation rate
--±0.2±0.5
Temperature drift coefficientPositive logic: CNT suspended or connected to 3.5-15V for startup, connected to 0-1.2V for shutdown-0.02--+0.02%/℃
Ripple&Noise20M bandwidth, external 470uF or above capacitor test--150240mVp-p
-20--+10%
Remote compensation of output voltage (Sense)
----105%
Over Temperature ProtectionThe highest temperature on the surface of the metal substrate of the product105115125℃
125--140%
6.5
--9A
Hiccup style, sustainable, self-healing
sProject Working conditionMin.Typ.Max.Unit
Isolation VoltageInput-outputTest time 1 minute, leakage current less than 3mA----2100
Input - ShellTest time 1 minute, leakage current less than 3mA----2100VDC
Output - ShellTest time 1 minute, leakage current less than 3mA----500VDC
--330--KHz
mean time between failures
推荐电路图-110S-1 拷贝
