  4. DC DC 1W
  5. B1505S/B1503S/B1509S/B1512S/B1515S/B1524S-1WR3 15V to 3.3/5/9/12/15/24V1W DC to DC 88% transfer efficiency power module/converter
    $0.62
B_S-1WR3 Series Mode list 拷贝
2. transfer efficiency 80%(Typ)
10. Adopts high quality environmental protection, waterproof and heat conducting adhesive for filling and sealing, moisture-proof and vibration proof, meeting the waterproof and dustproof IP65 standard
Storage temperture-40—+80 ℃ ℃
Atmospheric pressure80—106 Kpa Kpa
Related input voltage5Vdc
Input voltage range4.5-5.5Vdc
Maximum input current≤0.3A
Reflection ripple current15mA
DC5V rated input voltage series
Impulse voltage≤9Vdc
Starting voltage4.5Vdc
Start-up delay---msRated input voltage and costant resistance load
Output Characteristics(5v/200mA)
No load rated output voltage5V±15%Vdc
Short-time maximum output current≥220mA
Rated output current200mA
Voltage regulation±1.5%
Load regulation ±12%
Transfer efficiency Vin=5Vdc, output full load 80%
Output grain sweep noise(mVp-p)Pure resistance load, 20MHz bandwidth, peak to peak valuemV
Outputting the maximum voltage 110-160%Vdc
Insulation resisitanceInput- output, insulation volaltge 500VDC/1000MΩMΩ
Isolation capacitanceInput- output, 100KHz/0.1V 20pF-
Cout CapacitanceFilter capacitor2.2-10μA/50V
