  4. half-brick power module
  5. DC/DC half-brick power module 100Q-48S05A isolated and stabilized 48V to 5V single circuit 100W
    $33.05
18V input voltage, full load output----8A
----20mA
Input impulse voltage (1sec. max)
beyond this range input may cause permanent damage
-0.7--80VDC
Starting voltage
----18
Under voltage protectNo load test, full load test will provide overcurrent protection in advance----17
Remote control foot (CNT)Positive logic: CNT suspended or connected to 3.5-15V for startup, connected to 0-1.2V for shutdownReference voltage - VIN
Negative logic: CNT suspended or powered off when connected to 3.5-15V, powered on when connected to 0-1.2V voltage
--±0.1±0.2
Load regulation rate
-0.7--±0.2
Temperature drift coefficientPositive logic: CNT suspended or connected to 3.5-15V for startup, connected to 0-1.2V for shutdown-0.02--+0.02%/℃
Ripple&Noise20M bandwidth, external 470uF or above capacitor test--80100mVp-p
-20--10%
Remote compensation of output voltage (Sense)
Over Temperature ProtectionThe highest temperature on the surface of the metal substrate of the product105115125℃
125--140%
22
--28A
Hiccup style, sustainable, self-healing
sProject Working conditionMin.Typ.Max.Unit
Isolation VoltageInput-outputTest time 1 minute, leakage current less than 3mA----1500
Input - ShellTest time 1 minute, leakage current less than 3mA----1500VDC
Output - ShellTest time 1 minute, leakage current less than 3mA----500VDC
--200--KHz
mean time between failures
推荐电路图-110S-1 拷贝
