IB0505S-W75R3/IB0512S/IB1205S/IB1212S/IB2405S/IB2412S-W75R3/ DCDC Isolated non regulated dual output power converter module
Visitor3205
Price$1.05
1. Small SIP-4 package, international standard pin
3. Transfer efficiency up to 73%
4. Ripple/noise (20MHz bandwidth): 30mVp-p (Typ.)
5. Output short-circuit protection, self-recovery
Input characteristic:
| Item | Working Conditions | Min. | Typ. | Max. | Unit | |
| Input voltage range(full-load/ no-load) | 5VDC input series | 3.3V/5V DC output | -- | 209/8 | 221/-- | mA |
| 9V/12V DC output | -- | 208/12 | 221/-- | |||
| 12VDC input series | 3.3V DC output | -- | 92/8 | 98/-- | ||
| 5V DC output | -- | 87/8 | 92/-- | |||
| 12V DC output | -- | 86/8 | 91/-- | |||
| 24VDC input series | 3.3V DC output | -- | 46/8 | 51/-- | ||
| 5V DC output | -- | 44/8 | 48/-- | |||
| 12V DC output | -- | 43/8 | 47/-- | |||
| Reflected ripple current | -- | 15 | -- | |||
Impulse Voltage | 5VDC input series | -0.7 | -- | 9 | Vdc | |
| 12VDC input series | -0.7 | -- | 18 | |||
| 24VDC input series | -0.7 | -- | 30 | |||
| Input fliter typle | Capacitive filtering | |||||
| Hot plug | Non-support | |||||
Output characteristic:
| Item | Working and testing condition | Min. | Typ. | Max. | Unit | |
| Output Voltage Accuracy | -- | -- | ±3.0 | % | ||
| Linear adjustment rate | Input voltage variation ±5% | -- | -- | ±0.25 | % | |
| Load adjustment rate | 10%~100% load | -- | +1 | +2 | % | |
| Ripple & Noise | Pure resistive load, 20HMz bandwidth, peak-to-peak | -- | 50 | 100 | mVp-p | |
General characteristic:
| Item | Working condition | Min. | Typ. | Max. | Unit |
| Insulation voltage | Input output, test time of 1 minute, leakage current less than 1mA | 1500 | -- | -- | VDC |
| Insulation resistance | Input output, insulation voltage 500VDC 1000-M Ω | 1000 | -- | -- | MΩ |
| Isolation capacitor | Input output, 100KHz/0.1V --40-- pF | -- | 20 | -- | pF |
| Working temperature | Use reference temperature derating curve chart | -40 | -- | +85 | ℃ |
| Temperature rise of the casing during operation | -- | 25 | -- | ||
| Storage humidity | No condensation | 5 | -- | 95 | %RH |
| Pin resistance to welding temperature | Welding point distance from the shell 1.5mm, 10 seconds | -- | -- | +300 | ℃ |
| Switching frequency | Full load, nominal voltage input | -- | 100 | -- | KHz |
| Shock | 10-55Hz, 10G, 30 Min. along X, Y and Z | ||||
| Shell material | Black flame retardant and heat-resistant plastic (UL94V-0) | ||||
| Minimum time between failures | MIL-HDBK-217F@25℃ | 3.5X10 6 | -- | -- | Hrs |
