  4. DC DC 50W
  5. URB4805LMD-50WR3 URB4812/URB4815/URB4824LMD-50WR3 DC-DC isolated Stable voltage output short circuit protection power converter module
    $11.65
URBxxxxLMD-50WR3 Series Mode list 拷贝
1. Wide input voltage range 4:1, isolated regulated output 50W
4. Quick Start:1mS(Typ)
Storage temperture-40—+125 ℃℃
Input voltage range(fully loaded/unloaded)
24VDC Input Series, norminal input voltage12V-2314/22367
15v-2289/22340
24v-2289/22340
±12V-2314/22367
±15v-2314/22367
±24v-2340/22394
48VDC Input Series, norminal input voltage9V-1170/11197
12V-1170/11197
15V-1157/11183
24V-1144/11170
±9V-1157/11183
±12V-1157/11183
±15v-1157/11183
±24v-1170/11197
110VDC Input Series, norminal input voltage9V-505/0.5516
12V-505/0.5516
15V-499/0.5510
24V-499/0.5510
±9V-505/0.5516
±12V-505/0.5516
±15v-499/0.5510
±24v-499/0.5510
Reflected Ripple Currentnominal Input Series
--40--mA
Impulse voltage  (Isec.max)24VDC Input Series
-0.7--50VDC
48VDC Input Series
-0.7--100
110VDC Input Series
-0.7--180
Start voltage24VDC nominal input series, nominal input voltage
--9
48VDC nominal input series, nominal input voltage
--18
110VDC nominal input series, nominal input voltage
--40
Input undervoltage protection24VDC nominal input series, nominal input voltage
5.58.0-
1215.5-
3034-
PI filter type
-±1.0%±2.0%-±2.0%±3.0%
±0.2%±0.5%-±1.5%±2.0%
Load adjustment rate
20%~100% rate
load, balanced
±0.5%
±1.0%-±4.0%±5.0%
FMSEselected according to the actual input current of the customer
