  4. Interface power module
  5. Hi-link TD521D485H-A high-speed communication isolation interface module single channel automatic transceiver RS485
    $1.50
TD521D485H-A:
https://drive.google.com/file/d/1CvAMBlFA0D6Wr99U9CFEZ_KfVaYQ1H4X/view?usp=sharing
  • Built in high-efficiency isolated power supply
  • Automatic data transmission and reception function
  • Baud rate up to 500kbps
  • Isolation and voltage withstand at both ends 3000VDC
  • Working environment temperature:- 40℃~+85℃
  • The same network can support connecting 128 nodes
  • Integrating isolation and ESD bus protection functions
  • Standardized packaging method, good compatibility performance
D321D485H-A/ TD521D485H-A,the main function is to convert logical levels into differential levels of RS485 protocol, achieve signal isolation, and is an RS485 protocol transceiver module that uses IC integration technology to achieve power isolation, signal isolation, RS485 communication, and bus protection.
The product has a built-in constant voltage isolation power supply, which can achieve 3000VDC electrical isolation. In addition, the product has automatic switching of transmission and reception functions, eliminating the need for CON pins for transmission and reception control, which reduces the complexity of the design to a certain extent.
Limited characteristic
Projectworking conditonMin.
Typ.
Max.Unit
Input impulse voltage (1sec. max.)
3.3VDC input series
-0.7
5
Vdc
5VDC input series
-0.7
-7
Pin soldering temperatureWelding point distance from shell 1.5mm, 10 seconds----
300
Input characteristic(3.3V series)
ProjectsymbolMin.Typ.Max.Unit
Input power supply voltage
Vdc
3.15
3.3
3.45
Vdc
TXD logic levelHigh level
VIH
0.7VCC
3.3
3.6
Low level
VIL
0
0.8
VOH
VCC-0.4
3.1
Low level
VOL
0
0.2
0.4
TXD driving current
IT
2
mA
RXD output currentIR--
--10
serial interfaceOnly compatible with UART interface of+3.3V
Input characteristic(5V series)
Vdc
4.75
5
5.25
Vdc
VIH
0.7VCC
5
5.5
Low level
VIL
0
0.8
VOH
VCC-0.4
4.8
Low level
VOL
0
0.2
0.4
TXD driving current
IT
2
mA
--10
serial interfaceOnly compatible with UART interface of+5V
Transmit characteristic
data-delay
TXD sending delay
tT----250ns
RXD receiving delay
tR
----110
Iutput characteristic
differential voltage level
Vdiff(d),no load resistor
1.5
Vdc
differential input impedance
-7V≤VCM≤+12V
96
kΩ
Built in pull-up and pull-down
resistors
--47--
Isolation output power supply
voltage
Rated input voltage 4.955.3
Vdc
Bus interface protectionESD electrostatic protection
Note: The isolated output power pin is only used for external pull-up and pull-down resistors (recommended maximum current<25mA) and is not recommended for other purposes.
More detail please contact us: sales@hlktech.com
