HLK-10D1212B 12V 10W 830mA DC to DC 86% transfer input power supply module input 9-18V
Visitor484
Price$4.58
1. Ultra wide range input (2:1), output 10W
2. Conversion efficiency 86%(Typ)
4. Ultra low standby power consumption: 0.3W (typical)
5. Ultra fast start: 100mS (typical)
Related input voltage | 12 | Vdc | |
Input voltage range | 9-18 | Vdc | |
Maximum input current | ≤1.2 | A | |
Reflection ripple current | ---- | mA | DC12V rated input voltage series |
Impulse voltage | ≤30 | Vdc | |
Start-up delay | 100 | ms | Rated input voltage and constant resistance load |
Output Characteristics(12V/830mA)
No load rated output voltage | 12V±2% | Vdc | |
Short-time maximum output current | ≥900 | mA | |
Rated output current | 830 | mA | |
Load regulation | ±1 | % | |
Transfer efficiency | Vin=12Vdc, output full load 80 | % | |
Output over-voltage protection | Outputting 110-160% the maximum voltage | Vdc | |
MOV1/Varistor | Protest the circuit from damage when the module is abnormal | 14D333K |
LDM1/Common mode inductance | EMI Filtering | Inductance: 2mH |
E1,E2 Electrolytic capacitor | Filter capacitor | 470uF/50V |
1 | 2 | 3 | 4 | 5 | 6 |
Input negative | Input positive | Output positive | ---- | Output positive | ---- |
