  4. DC DC 10W
  5. HLK-10D1205B 5V 10W 2000mA DC to DC 86% transfer input power supply module
    $4.58
产品型号-3
1. Ultra wide range input (2:1), output 10W
2. Conversion efficiency 86%(Typ)
4. Ultra low standby power consumption: 0.3W (typical)
5. Ultra fast start: 100mS (typical)
10. It is sealed with high quality environmental protection waterproof and thermal conductive glue, moisture proof and vibration proof, and meets the requirements of waterproof and dust proof IP65.
11. High reliability, long life design, long continuous working time
Storage temperture-40—+80 ℃
Related input voltage12Vdc
Input voltage range9-18Vdc
Maximum input current≤1.2A
Reflection ripple current----mA
DC12V rated input voltage series
Impulse voltage≤30Vdc
Starting voltage9Vdc
Start-up delay100msRated input voltage and constant resistance load
PI version
Output Characteristics(5V/1000mA)
No load rated output voltage5V±2%Vdc
Short-time maximum output current≥2200mA
Rated output current2000mA
Voltage regulation±0.5%
Load regulation ±1%
Transfer efficiency Vin=12Vdc, output full load 76%
Output ripple and noise (mVp-p)≤100 Pure resistance load, 20MHz bandwidth, peak to peak valuemV
Outputting 110-160% the maximum voltage Vdc
MOV1/VaristorProtest the circuit from damage when the module is abnormal14D333K
LDM1/Common mode inductanceEMI FilteringInductance: 2mH
E1,E2 Electrolytic capacitorFilter capacitor470uF/50V
LDM2/Differential mode inductanceEMI filtering4.7-68uH
CY1/Y2 Capacitance
1nF/250vAC
123456
VIN-VIN+VO+NPGNDNC
Input negativeInput positiveOutput positive----Output positive----
