  4. DC DC 5W
  5. HLK-5D2412 12V 5W 420mA DC to DC 84% transfer input power supply module
    $3.23
产品型号-3
1. Ultra wide range input (2:1), output 5W
2. Conversion efficiency 84%(Typ)
4. Ultra low standby power consumption: 0.3W (typical)
5. Ultra fast start: 100mS (typical)
10. It is sealed with high quality environmental protection waterproof and thermal conductive glue, moisture proof and vibration proof, and meets the requirements of waterproof and dust proof IP65.
11. High reliability, long life design, long continuous working time
Storage temperture-40—+80 ℃
Related input voltage24Vdc
Input voltage range18-36Vdc
Maximum input current≤0.7A
Reflection ripple current----mA
DC12V rated input voltage series
Impulse voltage≤50Vdc
Starting voltage9Vdc
Start-up delay100msRated input voltage and constant resistance load
PI version
Output Characteristics(12V/420mA)
No load rated output voltage12V±2%Vdc
Short-time maximum output current≥520mA
Rated output current420mA
Voltage regulation±0.5%
Load regulation ±1%
Transfer efficiency Vin=24Vdc, output full load 84%
Output ripple and noise (mVp-p)≤100 Pure resistance load, 20MHz bandwidth, peak to peak valuemV
Outputting 110-160% the maximum voltage Vdc
MOV1/VaristorProtest the circuit from damage when the module is abnormal14D330K
ldm1/Common mode inductanceEMI FilteringInductance: 10-30mH
E1,E2 Electrolytic capacitorFilter capacitor100uF/50V
LDM2/Differential mode inductanceEMI filtering10-68uH
123456
VIN-VIN+VO+NPGNDNC
Input negativeInput positiveOutput positive----Output positive----
