HLK-5D1224 24V 5W 210mA DC to DC 84% transfer input power supply module
Visitor493
Price$3.23
1. Ultra wide range input (2:1), output 5W
2. Conversion efficiency 84%(Typ)
4. Ultra low standby power consumption: 0.3W (typical)
5. Ultra fast start: 100mS (typical)
Related input voltage | 12 | Vdc | |
Input voltage range | 9-18 | Vdc | |
Maximum input current | ≤0.7 | A | |
Reflection ripple current | ---- | mA | DC12V rated input voltage series |
Start-up delay | 100 | ms | Rated input voltage and constant resistance load |
Output Characteristics(24V/210mA)
No load rated output voltage | 24V±2% | Vdc | |
Short-time maximum output current | ≥310 | mA | |
Rated output current | 210 | mA | |
Load regulation | ±1 | % | |
Transfer efficiency | Vin=12Vdc, output full load 84 | % | |
Output over-voltage protection | Outputting 110-160% the maximum voltage | Vdc | |
MOV1/Varistor | Protest the circuit from damage when the module is abnormal | 14D330K |
ldm1/Common mode inductance | EMI Filtering | Inductance: 10-30mH |
LDM2/Differential mode inductance | EMI filtering | 10-68uH |
1 | 2 | 3 | 4 | 5 | 6 |
Input negative | Input positive | Output positive | ---- | Output positive | ---- |
