  4. DC DC 5W
  5. HLK-5D1205 5V 5W 1000mA DC to DC 84% transfer input power supply module replace HDD5-12S05A3
    $3.23
产品型号-3
1. Ultra wide range input (2:1), output 5W
2. Conversion efficiency 84%(Typ)
4. Ultra low standby power consumption: 0.3W (typical)
5. Ultra fast start: 100mS (typical)
Storage temperture-40—+80 ℃
Related input voltage12Vdc
Input voltage range9-18Vdc
Maximum input current≤0.7A
Reflection ripple current----mA
DC12V rated input voltage series
Impulse voltage≤50Vdc
Starting voltage9Vdc
Start-up delay100msRated input voltage and constant resistance load
PI version
Output Characteristics(5V/1000mA)
No load rated output voltage5V±2%Vdc
Short-time maximum output current≥1200mA
Rated output current1000mA
Voltage regulation±0.5%
Load regulation ±1%
Transfer efficiency Vin=12Vdc, output full load 84%
Output ripple and noise (mVp-p)≤100 Pure resistance load, 20MHz bandwidth, peak to peak valuemV
Outputting 110-160% the maximum voltage Vdc
MOV1/VaristorProtest the circuit from damage when the module is abnormal14D330K
ldm1/Common mode inductanceEMI FilteringInductance: 10-30mH
E1,E2 Electrolytic capacitorFilter capacitor100uF/50V
LDM2/Differential mode inductanceEMI filtering10-68uH
123456
VIN-VIN+VO+NPGNDNC
Input negativeInput positiveOutput positive----Output positive----
