  4. DC DC 1W
  5. 12V to 15V 1W 67mA DC to DC 80% transfer input power supply module HLK-1D1215
    $1.21
产品型号-3
2. transfer efficiency 80%(Typ)
10. Adopts high quality environmental protection, waterproof and heat conducting adhesive for filling and sealing, moisture-proof and vibration proof, meeting the waterproof and dustproof IP65 standard
Storage temperture-40—+80 ℃
ItemsWorking conditionsUnitNotes
Related input voltage12Vdc
Input voltage range10.8-13.2Vdc
Maximum input current≤0.2A
Reflection ripple current15mA
DC12V rated input
voltage series
Impulse voltage≤18Vdc
Starting voltage10.8Vdc
Input under voltage protection---Vdc
Start delay time---VdcReted input voltage and constant resistance load
Capacitive filtering
Hot plug
Notes: test at room temperature
Output Characteristics(15V/200mA)
ItemsTechnical parametersUnitNotes
No-load rated output voltageVdcVdc15V±15%Vdc
Short time maximum output current≥77mA
Rated output current67mA
Voltage regulation±1.5%
Load regulation±6%
Conversion efficiencyVin=12Vdc, Output full load 80%
Output ripple and noise(m Vp-p)≤100  Pure resistive load, 20MHz bandwith, peak to peak valuemV
Output over-voltage protectionOutput 110-160% of the maximum voltageVdc
Insulation voltageInput-output, test time 1 minute, leakage current less than 1mA/1500V
Insulation resistanceInput-output, insulation voltage 500VDC/1000MΩ
Isolated capacitorInput-output,100KHz/0.1V 20pF
1. Due to limited space, the above is only a list of typical products. If you need products outside the list, please contact our sales department.
2. The maximum capacitive load indicates the maximum capacitive load that + Vo or -Vo can connect to. If it exceeds this value, the product will not start normally.
Cout CapacitanceFilter capacitor2.2-10μA/50V
