10-axis Vibration Accelerometer Gyroscope MEMS Sensor Attitude Inclination Magnetic Field Motion/posture Module
Visitor336
Price$5.26
Input Introduction
HLK-AS201 is a ten axis attitude sensor module developed and produced by Hi-link Electronics. The module integrates high-precision accelerometers, gyroscopes, magnetometers, and barometers, and uses high-performance microprocessors and advanced filtering algorithms to quickly calculate the real-time attitude of the module.
Product Characteristic
The module integrates high-precision accelerometers, gyroscopes, magnetometers, and barometers.
Adopting advanced digital filtering technology can effectively reduce measurement noise and improve measurement accuracy
The Z-axis heading angle is filtered and fused with a geomagnetic sensor, which solves the cumulative error caused by the drift of gyroscope integration in the 6-axis algorithm,
long term stable output of heading angle data.
Attention: Due to magnetic field detection, calibration is required before use, and it is necessary to stay away from the magnetic field during use
at least 20 centimeters away from hard magnetic objects such as interference areas, electronic devices, magnets, speakers, etc
High performance 32-bit floating-point DSP processor with a running frequency of up to 240MHz
Based on Bluetooth BLE5.1 wireless transmission, the speed is faster and the transmission distance is longer, reaching up to 50m in open environments
Support OTA Bluetooth wireless upgrade module firmware
Default onboard antenna, with extremely low cost control and strong wireless signal under low-cost conditions
Wide working voltage of 1.8Vto3.4V, typical value of 3.0V
Terechnical specifications
Name | Parameter indicators |
Range | Acceleration: ± 16g (resolution 0.0005g) Angular velocity: ± 2000 °/s (resolution 0.031 °/s) Magnetic field: ± 30Gauss Euler angle: X and Z angles: ± 180 °, Y angle: ± 90 ° (resolution ± 1 °) Temperature: -45 ℃~85 ℃ Air pressure: 300~1200hPa Height: -500~9000m |
Accuracy | Acceleration: 0.01g (0.098m/s ²) Angular velocity: 0.03 °/s Euler angle: X and Y angles: ± 1 °, Z angle: ± 5 ° (without magnetic interference) Temperature: 0.01 ℃ (on board temperature) Air pressure: 0.006hPa Height: 0.05m (when the air pressure is stable) |
Proactive reporting frequency | 0.1-20Hz adjustable,default 20Hz |
Serial TTL | Baud rate (adjustable from 4800 to 921600, default 115200), 8 data bits, 1 stop bit, no checksum |
Bluetooth performance | Supports Bluetooth 5.1 and backward compatibility, with a transmission power of+6dBm and a reception power of -90dBm. Tested to have a maximum transmission distance of 50m without obstruction Supports direct connection and use of BLE host devices such as Android, iOS, Linux, Windows, etc |
Power consumption | Average current: 9mA Peak current: 26mA |
Working voltage | Input voltage VBAT2.2V-5.5VDC, typical: 3.3V, please refer to the typical application schematic to design the power supply |
Operation temperature | -40℃~85℃ |
Storage temperature | -40℃~100℃; Relative humidity ≤ 5% |
Weld parameter | Maximum temperature rise of 3 ℃/s, maximum gradual decrease rate of 6 ℃/s, maximum welding temperature of 217 ℃, maximum impact temperature of 230 ℃/10s |
Static protection level | HBM:2000V;CDM:500V |
