  4. 10G radar sensor module
  5. 10GHz Doppler X-band 1T1R Sensing Range 7m Micro/motion Radar Sensing Sensor Module HLK-LD102V Widely Using in Smart Switch
    $1.28
HLK-LD101V updated version:
ld101v-102v 拷贝
HLK-LD101V is an X-band radar module working at 10.525GHz. Based on the Doppler effect, this design uses fixed-frequency, directional transmitting and receiving antennas, which are first combined with chip integration technology and microwave antennas on the market. It has the characteristics of anti-interference, small size, no wall penetration, high stability, good consistency, and good clutter and high-order harmonic suppression effect. The on-board integrated IF demodulation, signal amplification, digital processing, light intensity detection, timing and other functions are integrated on the module, and the serial port function is opened at the same time, which is convenient for users to adjust relevant parameters. This product adopts pulse power supply mode, and the average power consumption can be reduced to 7mA.
 Working frequency 10.525GHz
 Wide voltage operation:+3.3V~15V
 Module size:20mm*25mm*4mm
 The sensing distance is about 7m (straight line distance)
 Detect angle 100°
 Maximum transmit power:2dBm
 Maximum receiving sensitivity:-95dBm
 Motion detection
 Onboard integrated transmit and receive antennas
Application Scenarios
 Smart home
 Smart lighting
 Smart home appliances
 Smart security
Input parameters
SymbolParametersTest conditionMinTyp.MaxUnit
VCCWorking voltage
3.3
15V
IWorking currentVCC=5V
81235mA
Output Parameters
FoscMicrowave frequencyVCC=3.3-12V
10.525
GHz
pTransmit powerVCC=3.3-12V
2dBm
VoutOutput voltage
2.93
3.1V
Iout
10mA
TwPower-on Stabilization time
101525s
