AC to DC 5V/9V/12V 40w Step Down mini Power Supply Module Converter Intelligent household switch power module
Visitor582
Price$10.36
Product Model
Model | Size | Output Power | Output Voltage | Output Current |
HKL-40M01 | 57.5*33.5*23.5 | 40W | 5V/9V/12V | 3300V |
Wide range input 90-265VAC/120-350VDC
Working Temerature -25—+60 ℃
Storage temperature -40—+80 ℃
Relative humidity 5—95 %
Altitude ≤2000 m
Input vlotage range 85-264VAC/120-350VDC
The maximum input current ≤0.9A
Input inrush current ≤50A
Input low start ≤50mS
External fuse recommended 2A/250Vac or 10Ω wire wound resistance, Slow blow
Output Features(5V)
Full-load rated output voltage 5.0±5%
Load regulation ±5%
Output over-current protection Output maximum load 130-200% A
Ripple/Noise ≤150mVp-p(Typ:50)
Output Features(9V)
Full-load rated output voltage 9.0±5%
Load regulation ±5%
Output Features(12V)
Full-load rated output voltage 12.0±5%
Load regulation ±5%
Meet UL/CE requirements
