F1505S-1WR3/F1503S/F1512S/F1515S/F1524S-1WR3 DC to DC 15V to 3.3V/5V/9V/12V/15V/24V 1W power module/converter
Visitor1332
Price$0.68
2. Isolation voltage≤3000VDC
Ripple & Noise | 30/80(max) | Mvp-p | Pure resistive load, 20MHz broadband, peak-to-peak |
Related input voltage | 5 | Vdc | |
Input voltage range | 4.5-5.5 | Vdc | |
Reflection ripple current | 15 | mA | DC5V rated input voltage series |
Impulse voltage | ≤9 | Vdc | |
Starting voltage | 4.5 | Vdc | |
Start-up delay | --- | ms | Rated input voltage and costant resistance load |
Input filter type | Capacitance filter type | ||
Output Characteristics(5v/200mA)
No load rated output voltage | 5V±15% | Vdc | |
Short-time maximum output current | ≥210 | mA | |
Rated output current | 200 | mA | |
Voltage regulation | ±1.5 | % | |
Load regulation | ±12 | % | |
Transfer efficiency | Vin=5Vdc, output full load 90 | % | |
Output grain sweep noise(mVp-p) | Pure resistance load, 20MHz bandwidth, peak to peak value | mV | |
Output over-voltage protection | Outputting the maximum voltage 110-160% | Vdc | |
Isolation capacitance | Input- output, 100KHz/0.1V 20pF | - |
