IB0505LS/IB0503LS/IB0512LS/IB0515LS/IB0524LS-1WR3 5V to 5V/3.3V/12V/15V/24V 1W DC to DC power module
Visitor4163
Price$0.88
2. Isolation voltage≤1500VDC
3. output short-circuit protection
4. The voltage of the input power supply is relatively stable.(Voltage variation range±10%Vin)
5. operating temperature range :-40°C~+85°C
6. The stability of output voltage is not required.
7. Small SIP package, plastic housing
8. International standard pin out method
9. Adopts high quality environmental protection, waterproof and heat conducting adhesive for filling and sealing, moisture-proof and vibration proof, meeting the waterproof and dustproof IP65 standard
Ripple & Noise | 30/80(max) | Mvp-p |
Impulse voltage | 3.3VDC Input Series | -0.7 | -- | 5 | VDC |
9VDC Input Series | -0.7 | -- | 15 | ||
12VDC Input Series | -0.7 | -- | 18 | ||
Output Voltage Accuracy | 100% load | -- | -- | ±3 | % | |
Linear adjustment rate | Input voltage variation ±1% | 3.3V output | -- | -- | ±3 | % |
others output | -- | -- | ±2 | % | ||
Load adjustment rate | 10%~100% load | 3.3VDC Output | -- | -- | ±3 | % |
Ripple & Noise | Pure resistive load, 20HMz bandwidth, peak-to-peak | -- | 50 | -- | mVp-p | |
Output short circuit protection | 1s | |||||
Note: ①The test method of ripple and noise twisted pair test method. ②The series module does not have the input anti-reverse function, it is strictly forbidden to reverse the input positive and negative connection, otherwise it will cause irreversible damage to the module |
Typical Application Reference Circuit( Recommended Parameters)
Conventinal applications
To further reduce the input and output ripple, a capacitor filter network can be connected to the input and output terminals, and the application circuit is shown in Figure 1.
However, care should be taken to select the appropriate filtering capacitor. If the capacitor is too large, it is likely to cause start-up problems. For each output, under the condition of ensuring safe and reliable operation, the recommended capacitive load value is detailed in Table 1. recommended capacitive load value details (Table 1).
2. EMI typical application circuit
3. Output load requirements
To ensure that the module works efficiently and reliably, the minimum output load must not be less than 10% of the rated load when in use. If the power you need is really small, please connect
a resistor in parallel between the positive and negative terminals of the output (the sum of the actual power used by the resistor is greater than or equal to 10% of the rated power and the rated power of the selected resistor must be more than 5 times the actual power used, otherwise the temperature of the resistor will be higher).
Product dimensions and pin definition, suggested printing layout
*Note: If the definition of each pin of the power supply module does not match with the selection manual, the label on the physical label shall prevail.
