24V to 9V 1111mA 10W DC to DC 91% transfer efficiency input power supply module converter URB2409YMD-10WR3
Visitor2014
Price$4.12
1. Ultra wide range input (4: 1), output 10W
2. Conversion efficiency 91% (Typ)
3.Isolation voltage 1500Vdc
4. Ultra-low standby power consumption: 0.036W (typical)
5. Ultra fast startup: 1mS (typical value)
6. Operating temperature range: -40 ° C ~ + 85 ° C
7. Input under voltage, output short circuit, over current, over voltage
8.Metal casing, low output ripple
9. International standard pins, PCB board in-line installation
10. Adopting high-quality environmental protection waterproof and thermally conductive adhesive potting, moisture-proof, vibration-proof, meet the waterproof and dustproof IP65 standard
Input voltage range | 18-36 | Vdc | |
Maximum input current | ≤0.7 | A | |
Reflection ripple current | 60 | mA | DC12V rated input voltage series |
Starting voltage | 18 | Vdc | |
Start-up delay | 100 | ms | Rated input voltage and constant resistance load |
Output Characteristics(9V/1111mA)
No load rated output voltage | 9V±2% | Vdc | |
Short-time maximum output current | ≥1111 | mA | |
Rated output current | 1011 | mA | |
Load regulation | ±1 | % | |
Transfer efficiency | Vin=24Vdc, output full load 86 | % | |
MOV1/Varistor | Protest the circuit from damage when the module is abnormal | 14D333K |
LDM1/Common mode inductance | EMI Filtering | Inductance: 2mH |
E1,E2 Electrolytic capacitor | Filter capacitor | 470uF/50V |
1 | 2 | 3 | 4 | 5 | 6 |
Input negative | Input positive | Output positive | ---- | Output negative | ---- |
