Hi-Link HLK-GD11 WiFi 6+5G LTE Gigabit Router with M.2 Interface 256MB DDR3/ 16MB Flash
Visitor384
Price$412.58
HLK-GD11 is a high-performance WiFi 6+5G router developed by Hi-Link electronics. It uses RM60 module, supports dual band WiFi 6, 5G module with M.2 interface, 12VDC power supply, 1 Gigabit Wan and 4 Gigabit LANs. Providing users with wireless long-distance data transmission services and routing functions.
Features
* IEEE 802.11 a/b/g/n/ac/ax wireless protocol
* Dual core 880mhzcpu, 256MB DDR3, 16MB flash
* Supports 20/40MHz bandwidth and 5G 20/40/80MHz in the 2.4GHz Band
* Supports 2.4g/ 5.8 GHz band,with data rate up to574+1201Mbps
* 2×2 MU-MIMO
* Bulit in TCP/IP protocol stack
* Supports wireless upgrade (OTA)
* 12V DC power supply
Simple Sepcifications:
Main chipset: RM60module-MT7621AT+MT7905DAN+MT7975DN
Main Frequency: 880MHz
RAM: DDR3 256MB
Flash: 16MB
Temperature: Ambient temperature: -20~50C, Storage:-40℃~70℃
Humidity: 5~95%(non-condensing)
Size: 186mm*110mm*31mm (without antenna)
Parameters |
WIFI part | Wireless standards | IEEE 802.11a/b/g/n/ac/ax |
frequency range | 2.412-2.484GHz 5.150-5.850GHz | |
2.4G RF parameters | 11b 11M: TX: 23±1.5dBm 11g 54M: TX: 20±1.5dBm 11n HT20 MCS7: TX: 19±1.5dBm 11n HT40 MCS7: TX: 19±1.5dBm 11ac VHT20 MCS8: TX: 17±1.5dBm 11ac VHT40 MCS9: TX: 17±1.5dBm 11ax HESU20 MCS11: TX: 16.5±1.5dBm 11ax HESU40 MCS11: TX: 16.5±1.5dBm | |
5.8G RF parameters | 11a 54M: TX : 18±1.5dBm 11n HT20 MCS7: TX : 18±1.5dBm 11n HT40 MCS7: TX : 18±1.5dBm 11ac VHT20 MCS8: TX : 17±1.5dBm 11ac VHT40 MCS9: TX : 16.5±1.5dBm 11ac VHT80 MCS9: TX : 16.5±1.5dBm 11ax HESU20 MCS11: TX : 15±1.5dBm 11ax HESU40 MCS11: TX : 15±1.5dBm 11ax HESU80 MCS11: TX : 15±1.5dBm | |
Number of channels | 2.4G:1-11 5.8G:36-165 | |
Antenna type | omnidirectional rod antenna, gain 6dbi (2.4G/5.8G dual-frequency antenna * 4) | |
5G part | Module interface | M.2 Interface |
5G frequency range | N28/N41/N78/N79 2G/3G/4G/5G Full netcom | |
Module support list | Quectel RM500U, RM500Q(Qualcomm) Fibocom FM650(Unisoc) | |
Antenna Type | Fully directional rod antenna with gain 6dbi (5G LTE full netcom antenna * 4) | |
Software parameters | Working mode | Router, Repeate, AP, Client, Bridge |
Wireless security | Wireless MAC address filtering, WPA-PSK, WPA2-PSK, WPA3 wireless encryption | |
Firmware upgrade | Web upgrade | |
Networking protocol | IPv4, TCP/UDP | |
User configuration | Web configuration | |
Electrical parameters | Power supply interface size | DC5.5*2.1mm |
power requirement | DC12V/1.5A | |
Other ports | Internet access | 1 Gigabit WAN port + 4 Gigabit LAN port |
USB | 1 USB2.0 Port | |
SIM card | 1 card slot(Nano SIM) | |
TF card | 1 TF card slot | |
Key | 1 reset button | |
Antenna interface | 2.4G/5.8G WiFi:SMA External screw inner needle *4 2G/3G/4G/5G netword :SMA External screw inner hole*4 |
Interface reference
* Front interface
Module size and FAQ
