AC to DC HLK-30M12C/30M05C/30M24C 9V/12V/24V 30W Step Down Mini Power Supply Module Converter Intelligent High Cost Performance
Visitor9982
Price$3.52
Brief Introduction
The 30W ultra-small series module power supply is a small, high-efficiency power supply module designed by Hi-link Electronics for customers. It has the advantages of global input voltage range, low temperature rise, low power consumption, high efficiency, high reliability, and high safety isolation. It has been widely used in industries such as smart home, automation control, communication equipment, and instrumentation.
2. Global universal input voltage (90~265Vac)
3. Low power consumption, green environmental protection, no-load loss<0.2W 4. Low ripple, low noise
Related input voltage | 100-240 | Vac | |
Input voltage range | 85-264 | Vdc | or 120-350V dc |
Maximum input current | ≤0.7 | A | |
Input inrush current | ≤50 | A | |
Input low start | ≤50 | mS | |
Long-term reliability | MTBF≥100000 | H | |
external fuse recommended | 2A/250Vac | Vdc | Slow blow |
No load rated output voltage | 5V±0.1 | Vdc | |
Full load rated output voltage | 5V±0.2 | Vdc | |
Short-time maximum output current | ≥6100 | mA | |
Rated output current | 6000 | mA | |
Voltage regulation | ±0.2 | % | |
Load regulation | ±0.5 | % | |
Input low voltage efficiency | Vin=115Vac, output full load ≥85 | % | |
Input high voltage efficiency | Vin=230Vac, output full load ≥87 | % | |
Output ripple and noise (mVp-p) | ≤100 Pure resistance load, 20MHz bandwidth,Load side 10uF and 0.1uF capacitance test | mV | |
Switching on/off overshoot amplitude | (Rated input voltage, output plus 10% load)≤5 | %Vo | |
Output over-current protection | Output maximum load 110-150% | A | |
Output short circuit protection | Direct short circuit in normal output and automatic return to normal operation after removal of short circuit | No-damage to the whole device |
Output Characteristics(9V/3300mA)
No load rated output voltage | 9V±0.1 | Vdc | |
Full load rated output voltage | 9V±0.2 | Vdc | |
Short-time maximum output current | ≥3400 | mA | |
Rated output current | 3300 | mA | |
Voltage regulation | ±0.3 | % | |
Input low voltage efficiency | Vin=115Vac, output full load ≥86 | % | |
Output Characteristics(12V/2500mA)
No load rated output voltage | 12V±0.1 | Vdc | |
Full load rated output voltage | 12V±0.2 | Vdc | |
Short-time maximum output current | ≥2600 | mA | |
Rated output current | 2500 | mA | |
Voltage regulation | ±0.4 | % | |
Output Characteristics(15V/2000mA)
No load rated output voltage | 15V±0.1 | Vdc | |
Full load rated output voltage | 15V±0.2 | Vdc | |
Short-time maximum output current | ≥2100 | mA | |
Rated output current | 2000 | mA | |
Output Characteristics(24V/1250mA)
No load rated output voltage | 24V±0.1 | Vdc | |
Full load rated output voltage | 24V±0.2 | Vdc | |
Short-time maximum output current | ≥1350 | mA | |
Rated output current | 1250 | mA | |
Fuse | Protest the circuit from damage when the module is abnormal | 2A/250Vac, Slow fuse |
Varistor | The cumulative surge is to protect the module from damage | 10D561K |
C1/Safety capacitance | Filtering, safety protection(EMC certification) | 0.1uF/275Vac |
L1/Common-mode inductance | EMI filtering | Sensible value 10-20mH, current 1-2A |
1 | 2 | 3 | 4 |
AC | AC | VO- | VO+ |
Dimension error:
Length, width, height and lead pitch error ±8%
Lead length error ±1mm
Lead diameter error ±0.2mm
Weight ≤80g
