URA2405YMD-20WR3 URA2412YMD/URA2415YMD/URA2424YMD DCDC power module 24V to 3.3/5/9/12/15/24V isolated dual output
Visitor6242
Price$7.22
1. Ultra wide range input (4:1), output 20W
Vibrate | Vibration coefficient 10~55Hz,10G,30min. along X,Y,Z | Meet the requirements of secondary road transportation |
Input current (full load/no load) | 24VDC Input Series | ±5V/±9V | - | 957/25 | 980/35 | m'A |
±12V | - | 926/1 | 947/2 | |||
±15V | - | 926/1 | 937/2 | |||
±24V | - | 916/1 | 937/2 | |||
48VDC Input Series | ±5V/±9V | - | 484/1 | 496/1.5 | ||
±12V | - | 458/1 | 469/1.5 | |||
±15V | - | 458/1 | 469/1.5 | |||
±24V | - | 458/2 | 469/1.5 | |||
Reflection ripple current | -- | 40 | -- | m'A | ||
Impulse voltage (lsec.max) | 24VDC Input Series | -0.7 | -- | 50 | VDC | |
Start Voltage | 24VDC Input Series | - | - | 9 | ||
48VDC Input Series | - | - | 18 | |||
Input undervoltage protection | 24VDC Input Series | 5.5 | 6.5 | - | ||
48VDC Input Series | 12 | 15.5 | - | |||
Input filter type | PI type | |||||
Project name | Working and testing condition | +Vo1 | -Vo2 | ||||
Min. | Typ. | Max. | Min. | Typ. | Max. | ||
Output load | load percentage | 0% | - | 100% | 0% | - | 100% |
Output voltage accuracy | - | ±1.0% | ±2.0% | - | ±2.0% | ±3.0% | |
Linear adjustment rate | input voltage range | - | ±0.2% | ±0.5% | - | ±1.5% | ±2% |
Load adjustment rate | 20%-100% rated load, balanced load | - | ±0.5% | ±1.0% | - | ±4.0% | ±5.0% |
Ripple & Noise | Pure resistive load,20MHz broadband, peak to peak, 5%-100% load | - | 50mVp-p | 80mVp-p | - | 50mVp-p | 80mVp-p |
Start time delay | - | 1ms | - | - | 1ms | - | |
Input vlotage adjustment | input voltage range | - | - | ±10% | - | no adjustment | - |
Dynamic response step deviation | 25% nominal load step | - | ±3.0% | ±5.0% | - | ±3.0% | ±5.0% |
Dynamic response recovery time | - | 300μs | 500μs | - | 300μs | 500μs | |
Output overvoltage protection | full voltage input range | 110%Vo | - | 160%Vo | |||
Output overcurrent protection | full voltage input range | 110%lo | 150%lo | 200%lo | |||
Output short circuit protection | full voltage input range | sustainable, self-recovery | |||||
MOV/Varistor | Protest the circuit from damage when the module is abnormal | 14D560K |
LDM1/Common mode inductance | EMI Filtering | Inductance: 10mH |
1 | 2 | 3 | 4 | 5 | 6 |
VIN- | VIN+ | VO+ | TRIM | GND | CTRL |
Input negative | Input positive | Output positive | Voltage regulator | Output negative | Remote end |
