110V to 5V 10W 1000mA DC to DC 91% transfer input power supply module input 40-160V URB1D05YMD-10WR3
Visitor2551
Price$4.72
1. Ultra wide range input (4:1), output 10W
Related input voltage | 110 | Vdc | |
Input voltage range | 40-160 | Vdc | |
Reflection ripple current | 20 | mA | DC12V rated input voltage series |
Impulse voltage | ≤200 | Vdc | |
Starting voltage | 40 | Vdc | |
Input undervoltage protection | 36 | Vdc | |
Output Characteristics(5V/2000mA)
Short-time maximum output current | ≥2200 | mA | |
Rated output current | 2000 | mA | |
Load regulation | ±1 | % | |
Transfer efficiency | Vin=110Vdc, output full load 91 | % | |
MOV1/Varistor | Protest the circuit from damage when the module is abnormal | 14D561K |
LDM1/Common mode inductance | EMI Filtering | Inductance: 10-30mH |
CO,C1 Ceramic capacitors | Filter capacitor | 0.47uF/250V |
E1,E2 Electrolytic capacitor | Filter capacitor | 63uF/250V |
LDM2/Differential mode inductance | EMI filtering | 10-68uH |
1 | 2 | 3 | 4 | 5 | 6 |
Input negative | Input positive | Output positive | ---- | Output negative | ---- |
