URA1D05YMD-12WR3 URA1D12YMD/ URA1D24YMD DC-DC isolated power module isolation stablized dual output power converter module
Visitor3077
Price$5.25
1. Ultra wide range input (4:1), output 12W
Vibrate | 10-55Hz,10G,30Min.alongx,YandZ |
Input current (full load/no load) | 24VDC Input Series | 3.3V | - | 503/1 | 515/2 | mA |
others | - | 549/1 | 602/2 | |||
48VDC Input Series | 3.3V | - | 252/0.5 | 258/1 | ||
others | - | 274/0.5 | 301/1 | |||
110VDC Input Series | 3.3V | - | 110/0.3 | 113/0.5 | ||
others | - | 128/0.3 | 136/0.5 | |||
Reflection ripple current | 24VDC input series, output voltage | - | 40 | - | mA | |
48VDC input series, output voltage | - | 30 | - | |||
110VDC input series, output voltage | - | 20 | - | |||
Impulse voltage (lsec.max) | 24VDC Input Series | -0.7 | -- | 50 | VDC | |
Start Voltage | 24VDC Input Series | - | - | 9 | ||
48VDC Input Series | - | - | 18 | |||
110VDC Input Series | - | - | 40 | |||
Input undervoltage protection | 24VDC Input Series | 5.5 | 6.5 | - | ||
48VDC Input Series | 12 | 15.5 | - | |||
110VDC Input Series | 32 | 36 | - | |||
Input filter type | PI type | |||||
Project name | Working and testing condition | +Vo1 | -Vo2 | ||||
Min. | Typ. | Max. | Min. | Typ. | Max. | ||
Output load | load percentage | 0% | - | 100% | 0% | - | 100% |
Output voltage accuracy | - | ±1.0% | ±2.0% | - | ±2.0% | ±3.0% | |
Linear adjustment rate | input voltage range | - | ±0.2% | ±0.5% | - | ±1.5% | ±2% |
Load adjustment rate | 20%-100% rated load, balanced load | - | ±0.5% | ±1.0% | - | ±4.0% | ±5.0% |
Ripple & Noise | Pure resistive load,20MHz broadband, peak to peak, 5%-100% load | - | 50mVp-p | 80mVp-p | - | 50mVp-p | 80mVp-p |
Start time delay | - | 1ms | - | - | 1ms | - | |
Input vlotage adjustment | input voltage range | - | no adjustment | - | - | no adjustment | - |
Dynamic response step deviation | 25% nominal load step | - | ±3.0% | ±5.0% | - | ±3.0% | ±5.0% |
Dynamic response recovery time | - | 300μs | 500μs | - | 300μs | 500μs | |
Output overvoltage protection | full voltage input range | 110%Vo | - | 160%Vo | |||
Output overcurrent protection | full voltage input range | 110%lo | 150%lo | 200%lo | |||
Output short circuit protection | full voltage input range | sustainable, self-recovery | |||||
Component No. | 24V input | 48V input | 110V input |
Fuse | Follow up on customer needs and connect corresponding fuses | ||
MOV1/Varistor | 14D560K | 14D101K | 14D201K |
ldm1/Common mode inductance | 10mH | 15mH | 30mH |
CO,C1 Ceramic capacitors | 1uF/50V | 1uF/100V | 0.47uF/250V |
E1,E2 Electrolytic capacitor | 100uF/50V | 100uF/100V | 63uF/200V |
LDM2/Differential mode inductance | 1nF/250Vac |
Component No. | 3.3V output | ±5V or 5V output | ±9/±12V or 9V/1V output | ±15 or 15V output | ±24 or 24V output |
LDM3/Common mode inductance | 0.47uH | 1uH | 2.2uH | 2.2uH | 4.7uH |
LDM4/Common mode inductance | 0.47uH | 1uH | 2.2uH | 2.2uH | 4.7uH |
LDM5/Common mode inductance | - | 1uH | 2.2uH | 2.2uH | 4.7uH |
C2,C3 Electrolytic capacitor | 220uF | 220uF | 100uF | 100uF | 68uF |
C5,C6 Electrolytic capacitor | 220uF | 220uF | 100uF | 100uF | 68uF |
C4 Ceramic capacitors | 1uF/50V |
Single(S) | 1 | 2 | 3 | 4 | 5 | 6 |
-VIN | +VIN | +VO | NP | GND | CTRL | |
Input negative | Input positive | Output positive | ---- | Output positive | remote terminal | |
Dual(D) | -VIN | +VIN | +VO1 | COM | -VO2 | CTRL |
Input negative | Input positive | Output positive | common terminal | output negative2 | remote terminal |
