  4. DC DC 12W
  5. URA2405YMD-12WR3 URA2412YMD/ URA2415YMD/URA2424YMD DC-DC isolated dual output 24V to 5v/12v/15v/24v power converter module
    $5.16
产品型号 拷贝
1. Ultra wide range input (4:1), output 12W
2. Conversion efficiency 91%(Typ)
4. Ultra low standby power consumption: 0.036W (typical)
5. Ultra fast start: 1mS (typical)
Vibrate10-55Hz,10G,30Min.alongx,YandZ
Input current
(full load/no load)
24VDC Input Series3.3V-503/1515/2mA
others-549/1602/2
48VDC Input Series3.3V-252/0.5258/1
others-274/0.5301/1
110VDC Input Series3.3V-110/0.3113/0.5
others-128/0.3136/0.5
Reflection ripple current24VDC input series, output voltage-40-mA
48VDC input series, output voltage-30-
110VDC input series, output voltage-20-
Impulse voltage
(lsec.max)
24VDC Input Series
-0.7--50
48VDC Input Series
-0.7--100
110VDC Input Series
-0.7--200
Start Voltage24VDC Input Series
--9
48VDC Input Series
--18
110VDC Input Series
--40
Input undervoltage protection
24VDC Input Series
5.56.5-
48VDC Input Series
1215.5-
110VDC Input Series
3236-
PI type
Project nameWorking and testing condition+Vo1-Vo2
Output load load percentage0%-100%0%-100%
-±1.0%±2.0%-±2.0%±3.0%
Linear adjustment rate
input voltage range-
±0.2%
±0.5%-±1.5%±2%
Load adjustment rate
20%-100% rated load, balanced load-±0.5%±1.0%-±4.0%±5.0%
Ripple & NoisePure resistive load,20MHz broadband, peak to peak, 5%-100% load
-50mVp-p80mVp-p-50mVp-p80mVp-p
Start time delay
-1ms--1ms-
Input vlotage adjustmentinput voltage range-no adjustment--no adjustment -
Dynamic response step deviation
25% nominal load step
-±3.0%±5.0%-±3.0%±5.0%
Dynamic response recovery time
-300μs500μs-300μs500μs
full voltage input range110%Vo-160%Vo
Output overcurrent protectionfull voltage input range110%lo150%lo200%lo
Output short circuit protectionfull voltage input range
sustainable, self-recovery
Component No.24V input48V input110V input
FuseFollow up on customer needs and connect corresponding fuses
MOV1/Varistor14D560K14D101K14D201K
ldm1/Common mode inductance10mH15mH30mH
CO,C1 Ceramic capacitors1uF/50V1uF/100V0.47uF/250V
E1,E2 Electrolytic capacitor100uF/50V100uF/100V63uF/200V
LDM2/Differential mode inductance1nF/250Vac
QQ_1727169617223
Component No.3.3V output±5V or 5V output
±9/±12V or 9V/1V
 output
±15 or 15V output±24 or 24V output
LDM3/Common mode inductance0.47uH1uH2.2uH2.2uH4.7uH
LDM4/Common mode inductance0.47uH1uH2.2uH2.2uH4.7uH
LDM5/Common mode inductance-1uH2.2uH2.2uH4.7uH
C2,C3 Electrolytic capacitor220uF220uF100uF100uF68uF
C5,C6 Electrolytic capacitor220uF220uF100uF100uF68uF
C4 Ceramic capacitors1uF/50V
Single(S)123456
-VIN+VIN+VONPGNDCTRL
Input negativeInput positiveOutput positive----Output positiveremote terminal
Dual(D)
-VIN+VIN+VO1COM-VO2CTRL
Input negativeInput positiveOutput positivecommon terminal
output negative2remote terminal
