10G radar module intelligent microwave sensor switch Doppler human motion detection sensor LD101
Visitor1751
Price$1.35
Introduction
HLK-LD101 is an X-band radar module working at 10.525GHz. Based on the Doppler effect, this design adopts
Using fixed-frequency, directional transmitting and receiving antennas, the current market is the first to use the combination of chip integration technology and microwave antennas. Tool
It has the characteristics of anti-interference, small size, no wall penetration, high stability, good consistency, and good clutter and high-order harmonic suppression effect. plate
The integrated IF demodulation, signal amplification, digital processing, light intensity detection, timing and other functions are integrated on the module, and the serial port is opened at the same time.
function, which is convenient for users to adjust relevant parameters. This product adopts pulse power supply mode, and the average power consumption can be reduced to 7mA
Operating frequency 10.525GHz
Wide voltage operation: +3.3V~15V
Modular package: 20mm*25mm*4mm
The sensing distance is not less than 1 meter (straight line distance)
Maximum transmit power: 2dBm
Maximum receiving sensitivity: -95dBm
Motion detection
Onboard integrated transmit and receive antennas
Typical Application
