  4. AC DC 5W
  5. AC to DC 15v5w Step Down Mini Intelligent Household Switch Power Supply Module Converter HLK-5M15
    $1.65
产品型号-3
Global universal input voltage(90-264VAC)
Working Temerature        -25—+60 ℃
Storage temperature        -40—+80 ℃
Relative humidity             5—95 %
Thermal methods             Natural cooling
Atmospheric pressure      80—106 Kpa
Altitude                            ≤2000 m
Vibration coefficient        10~500Hz,2G10min./1cycle, 60min.each along X,Y,Z axes. Meets secondary road transportation requirements
Rated input voltage        100-240Vac
Input vlotage range         85-264VAC/70-350VDC
The maximum input voltage             270VAC
The maximum input CURRENT        ≤0.2A
Input inrush current                         ≤10A
Input low start                                 ≤50mS
Long-term reliablity                         MTBF≥100000H
External fuse recommended           1A/250Vac or 10Ω wire wound resistance, Slow blow
Full-load rated output voltage          5.0±0.2%
Load regulation                                      ±0.5%
Switching on/off overshoot amplitude                5mS(115VAC/60mS,220VAC)
Output over-current protection Output maximum load             110-150% A
Ripple/Noise                   ≤100mVp-p(Typ:50)
