  3. Communication Module
  4. WiFi Router Module
  5. WiFi6 2.4G/5.8G Dual-frequency OpenWrt AX1800 MT7621+MT7905+MT7975 Gigabit ports* 5 UART Gigabit Router WiFi Module HLK-RM60
    $31.88
RM60详情图
Download Files
Introduction
HLK-RM60 is a high-performance embedded WIFI6 module launched by Hilink Electronics. The module complies with
IEEE standard 802.11a/b/g/n/ac/ax. The module integrates a 2.4G/5.8G radio frequency transceiver with a transmission rate.
High characteristics.
Featrures
  • Compatible IEEE 802.11 a/b/g/n/ac/ax
  • Dedicated high performance 32-bit RISC CPU
  • Sucol stack
  • Support Wireless upgrade(OTA)
  • 3.3V Single power supplypport 20/40MHz in 2.4G,Support 20/40/80MHZ in 5G
  • Support 2.4g/ 5.8 GHz ,Data rate up to 573+1201 Mbps
  • Support STA/AP
  • Built-in TCP/IP proto
    RM60-1
Specification
Items
Parameter
Model Number
HLK-RM60
Main Chipset
MT7621
Kernel
MIPS1004Kc
Main frequency
880MHz
RAM
DDR2 128MB
Flash
16MB
Temperature
Ambient temperature-20℃~60℃
Humidity
Using:10~95%(Non-condensing)
Stock:5~95%(Non-condensing)
Size
90mm×60mm
Application field
  • Smart home;
  • Instrumentation;
  • Wi-Fi Remote monitoring/control
  • Toy field;
  • Color LED control
  • Intelligent integrated management of fire protection and security
  • Smart card terminals, wireless POS machines, handheld devices, etc.
Size
SIZE
Interface description
INTERFACE
Enter the configuration web interface
Connect the computer's network port and the module's LAN port, open the computer browser, enter 192.168.16.254,
and you will enter the web login interface, enter the user name: root, password: admin, and then click the Login button
to enter the configuration interface.
CONFIGUE 1
Enter the configuration interface
configue 2
Set the WIFI name
After entering the web configuration interface, click WIFI, select WIFI configuration, enter the wifi configuration interface
configue 3
In this interface, you can see the WiFi name and mac address of 2.4g and 5.8g, click the config button to enter the
corresponding configuration interface
configue 4configue 4
After clicking the config button, you will enter the configuration interface of the corresponding ssid and password
configue 5
After the configuration is completed, click the following button to make the configured information take effect.
configue 6
