24V to 5V6A 30W DC to DC isolated transfer input power supply module URB2405LD-30WR3
Visitor5816
Price$6.75
UR(A)B_LD-30WR3 series product output power is 30W,4:1 wide voltage input range,efficiency up to 91%,conversional isolation volatge of 1500VDC,allowable operating temperature is -40℃to+85℃,
Wide input voltage range(4:1),Output 30W
Conversion efficiency91%(Typ)
Isolation voltage 1500Vdc
Ultra low power consumption:0.036W(Typ)
Fast startup:1ms(Typ)
Working temperature range:-40°C~+85℃
Input undervoltage , output short circuit , overcurrent,overvolatge protection
Metal case,low output ripple
International standard pins,PCB board in-line
Maximum input current | ≤1.45 | A | |
Reflected ripple | Nominal input voltage 40 | mA | DC 5V rated input voltage series |
Input undervoltage protection | 5.5-6.5 | Vdc | |
Output Characteristics(5V/3000mA)
Short-time maximum output current | ≥3000 | mA | |
Rated output current | 2900 | mA | |
Load regulation | ±0.5 | % | |
Transfer efficiency | Vin=5Vdc, output full load 90 | % | |
Output ripple and noise (mVp-p) | Pure resistive load, 20MHz bandwidth, peak to peak | mV | |
Component No. | 24V Input Product | 48V Input Product | 110V Input Product |
FMSE Fuse | Access the corresponding fuse accrding to customer needs | ||
MOV/Varistor | 14D560K | 14D101K | 14D201K |
LDM1/Common mode inductance | 10mH | 15mH | 30mH |
CO,C1 Ceramic capacitors | 100μF/50V | 100μF/100V | 100μF/200V |
E1,E2 Electrolytic capacitor | 1μF/50V | 1μF/100V | 0.47μF/250V |
LDM2/Differential mode inductance | 10μH | 15μH | 68μH |
