URB2405LD-20WR3 URB2412LD/URB2409LD/URB2424LD DCDC isolated and regulated power module 24V to 3.3/9/12/15/24V single channel
Visitor6139
Price$6.17
1. Ultra wide range input (4:1), output 20W
Maximum input current | ≤2.3 | A | |
Reflection ripple current | 40 | mA | DC12V rated input voltage series |
Output Characteristics(5V/4000mA)
Short-time maximum output current | ≥4200 | mA | |
Rated output current | 4000 | mA | |
Load regulation | ±1 | % | |
Transfer efficiency | Vin=24Vdc, output full load 90 | % | |
MOV/Varistor | Protest the circuit from damage when the module is abnormal | 14D560K |
LDM1/Common mode inductance | EMI Filtering | Inductance: 10mH |
1 | 2 | 3 | 4 | 5 | 6 |
VIN- | VIN+ | VO+ | TRIM | GND | CTRL |
Input negative | Input positive | Output positive | Voltage regulator | Output negative | Remote end |
