  4. DC DC 20W
  5. URB4805LD-20WR3 URB4812LD/URB4809LD/URB4824LD DCDC isolated and regulated power module 48V to 3.3/9/12/15/24V single output
    $6.50
URBXX-LD-20WR3 Series Mode list
1. Ultra wide range input (4:1), output 20W
2. Conversion efficiency 91%(Typ)
4. Ultra low standby power consumption: 0.036W (typical)
5. Ultra fast start: 1mS (typical)
10. It is sealed with high quality environmental protection waterproof and thermal conductive glue, moisture proof and vibration proof, and meets the requirements of waterproof and dust proof IP65.
11. High reliability, long life design, long continuous working time
Storage temperture-40—+80 ℃
Related input voltage24Vdc
Input voltage range9-36Vdc
Maximum input current≤2.3A
Reflection ripple current40mA
DC12V rated input voltage series
Impulse voltage≤50Vdc
Starting voltage9Vdc
Start-up delay1msRated input voltage and constant resistance load
PI version
Output Characteristics(12V/1666mA)
No load rated output voltage12V±2%Vdc
Short-time maximum output current≥1766mA
Rated output current1666mA
Voltage regulation±0.5%
Load regulation ±1%
Transfer efficiency Vin=24Vdc, output full load 90%
Output ripple and noise (mVp-p)≤100 Pure resistance load, 20MHz bandwidth, peak to peak valuemV
Output over-current protection
the maximum load 110-200% Vdc
MOV/VaristorProtest the circuit from damage when the module is abnormal14D560K
LDM1/Common mode inductanceEMI FilteringInductance: 10mH
E1,E2 Electrolytic capacitorFilter capacitor100uF/50V
LDM2/Differential mode inductanceEMI filtering4.7-68uH
CY1/Y2 Capacitance
1nF/250vAC
123456
VIN-VIN+VO+TRIMGNDCTRL
Input negativeInput positiveOutput positiveVoltage regulatorOutput negativeRemote end
