URA4812LD-20WR3 URA4805LD/URA4815LD/URA4824LD DCDC isolated power module with 48v to 3.3/5/9/15/24V dual output
Visitor6375
Price$6.95
1. Ultra wide range input (4:1), output 20W
Vibrate | 10-55Hz,10G,30Min.alongX,Yand Z | Meet the requirements of secondary road transportation |
Items | Working conditions | Min. | Typ. | Max. | Unit | |
Input current( full load/ no load) | 24V DC nominal input series, nominal input voltage | ±5V/9V | - | 968/25 | 992/35 | mA |
±12V | 926/1.5937/15 | 947/2 | ||||
±15V | 926/1.5937/55 | 937/2 | ||||
±24V | 936/2 | 957/2 | ||||
48V DC nominal input series, nominal input voltage | ±5V/9V | 484/1 | 496/1.5 | |||
±12V | 458/1 | 496/1.5 | ||||
±15V | 458/1 | 496/1.5 | ||||
±24V | 468/2 | 478/2 | ||||
110V DC nominal input series, nominal input voltage | ±5V/9V | 211/0.3 | 216/0.5 | |||
±12V | 202/0.3 | 206/0.5 | ||||
±15V | 200/0.3 | 204/0.5 | ||||
±24V | 200/0.3 | 204/0.5 | ||||
Refelected Ripple | Nominal INput Series | - | 40 | - | ||
Impulse voltage(Isec.max) | 24VDC Niminal Input Series | -0.7 | - | 50 | ||
48VDC Niminal Input Series | -0.7 | - | 100 | |||
110VDC Niminal Input Series | -0.7 | - | 180 | |||
Starting voltage | 24VDC Niminal Input Series | 5.5 | 6.5 | - | ||
48VDC Niminal Input Series | 12 | 15.5 | - | |||
110VDC Niminal Input Series | 30 | 34 | - | |||
Start time | Nominal input voltage and constant resistance | - | 1 | - | m | |
Input filter type | PI Type | |||||
Hot plug | No support | |||||
Remote control terminal(Ctrl) | Module on | Ctrl floating or connected to TTL high level | ||||
Module off | Ctrl is connected to GND or low level (0-1.2VDC) | |||||
Input current at shutdown | - | 0 | 1 | mA | ||
Note: Ctrl control pin voltage is relative to input pin GND |
Project name | Working and testing condition | +Vo1 | -Vo2 | ||||
Min. | Typ. | Max. | Min. | Typ. | Max. | ||
Output load | load percentage | 0% | - | 100% | 0% | - | 100% |
Output voltage accuracy | - | ±1.0% | ±2.0% | - | ±2.0% | ±3.0% | |
Linear adjustment rate | input voltage range | - | ±0.2% | ±0.5% | - | ±1.5% | ±2% |
Load adjustment rate | 20%-100% rated load, balanced load | - | ±0.5% | ±1.0% | - | ±4.0% | ±5.0% |
Ripple & Noise | Pure resistive load,20MHz broadband, peak to peak, 5%-100% load | - | 50mVp-p | 80mVp-p | - | 50mVp-p | 80mVp-p |
Start time delay | - | 1ms | - | - | 1ms | - | |
Input vlotage adjustment | input voltage range | - | - | ±10% | - | no adjustment | - |
Dynamic response step deviation | 25% nominal load step | - | ±3.0% | ±5.0% | - | ±3.0% | ±5.0% |
Dynamic response recovery time | - | 300μs | 500μs | - | 300μs | 500μs | |
Output overvoltage protection | full voltage input range | 110%Vo | - | 160%Vo | |||
Output overcurrent protection | full voltage input range | 110%lo | 150%lo | 200%lo | |||
Output short circuit protection | full voltage input range | sustainable, self-recovery | |||||
MOV/Varistor | Protest the circuit from damage when the module is abnormal | 14D560K |
LDM1/Common mode inductance | EMI Filtering | Inductance: 10mH |
1 | 2 | 3 | 4 | 5 | 6 |
VIN- | VIN+ | VO+ | TRIM | GND | CTRL |
Input negative | Input positive | Output positive | Voltage regulator | Output negative | Remote end |
