  4. DC DC 20W
  5. URA2412LD-20WR3 URA2405LD/URA2415LD/URA2424LD DCDC isolated power module with 24v to 3.3/5/9/15/24V dual output
    $6.70
URAXX_LD-20WR3 Series Mode list 拷贝 2
1. Ultra wide range input (4:1), output 20W
2. Conversion efficiency 91%(Typ)
4. Ultra low standby power consumption: 0.036W (typical)
5. Ultra fast start: 1mS (typical)
10. It is sealed with high quality environmental protection waterproof and thermal conductive glue, moisture proof and vibration proof, and meets the requirements of waterproof and dust proof IP65.
11. High reliability, long life design, long continuous working time
Vibrate10-55Hz,10G,30Min.alongX,Yand Z
ItemsWorking conditionsMin.Typ.Max.Unit
Input current( full load/ no load)
24V DC nominal input series, nominal input voltage±5V/9V-968/25992/35mA
±12V
926/1.5937/15947/2
±15V
926/1.5937/55937/2
±24V
936/2957/2
48V DC nominal input series, nominal input voltage±5V/9V
484/1496/1.5
±12V
458/1496/1.5
±15V
458/1496/1.5
±24V
468/2478/2
110V DC nominal input series, nominal input voltage±5V/9V
211/0.3216/0.5
±12V
202/0.3206/0.5
±15V
200/0.3204/0.5
±24V
200/0.3204/0.5
Refelected RippleNominal INput Series
-40-
Impulse voltage(Isec.max)24VDC Niminal Input Series-0.7-50
48VDC Niminal Input Series-0.7-100
110VDC Niminal Input Series-0.7-180
Starting voltage24VDC Niminal Input Series5.56.5-
48VDC Niminal Input Series1215.5-
110VDC Niminal Input Series3034-
Start timeNominal input voltage and constant resistance-1-m
PI Type
Hot plug
No support
Remote control terminal(Ctrl)Module on
Ctrl floating or connected to TTL high level
Module off
Ctrl is connected to GND or low level (0-1.2VDC)
Input current at shutdown
-01mA
Note: Ctrl control pin voltage is relative to input pin GND
Project nameWorking and testing condition+Vo1-Vo2
Output load load percentage0%-100%0%-100%
-±1.0%±2.0%-±2.0%±3.0%
Linear adjustment rate
input voltage range-
±0.2%
±0.5%-±1.5%±2%
Load adjustment rate
20%-100% rated load, balanced load-±0.5%±1.0%-±4.0%±5.0%
Ripple & NoisePure resistive load,20MHz broadband, peak to peak, 5%-100% load
-50mVp-p80mVp-p-50mVp-p80mVp-p
Start time delay
-1ms--1ms-
Input vlotage adjustmentinput voltage range--±10%-no adjustment -
Dynamic response step deviation
25% nominal load step
-±3.0%±5.0%-±3.0%±5.0%
Dynamic response recovery time
-300μs500μs-300μs500μs
full voltage input range110%Vo-160%Vo
Output overcurrent protectionfull voltage input range110%lo150%lo200%lo
Output short circuit protectionfull voltage input range
sustainable, self-recovery
MOV/VaristorProtest the circuit from damage when the module is abnormal14D560K
LDM1/Common mode inductanceEMI FilteringInductance: 10mH
E1,E2 Electrolytic capacitorFilter capacitor100uF/50V
LDM2/Differential mode inductanceEMI filtering4.7-68uH
CY1/Y2 Capacitance
1nF/250vAC
123456
VIN-VIN+VO+TRIMGNDCTRL
Input negativeInput positiveOutput positiveVoltage regulatorOutput negativeRemote end
