48V to 12V 10W 830mA DC to DC 91% transfer input power supply module converter URB4812YMD-10WR3
Visitor2643
Price$3.92
1. Ultra wide range input (4:1), output 10W
Related input voltage | 48 | Vdc | |
Input voltage range | 18-75 | Vdc | |
Maximum input current | ≤0.4 | A | |
Reflection ripple current | 30 | mA | DC12V rated input voltage series |
Impulse voltage | ≤100 | Vdc | |
Starting voltage | 18 | Vdc | |
Input undervoltage protection | 15 | Vdc | |
Output Characteristics(12V/833mA)
No load rated output voltage | 12V±2% | Vdc | |
Short-time maximum output current | ≥930 | mA | |
Rated output current | 830 | mA | |
Load regulation | ±1 | % | |
Transfer efficiency | Vin=48Vdc, output full load 91 | % | |
MOV1/Varistor | Protest the circuit from damage when the module is abnormal | 14D333K |
LDM1/Common mode inductance | EMI Filtering | Inductance: 2mH |
CO,C1 Ceramic capacitors | Filter capacitor | 1uF/100V |
E1,E2 Electrolytic capacitor | Filter capacitor | 100uF/100V |
1 | 2 | 3 | 4 | 5 | 6 |
Input negative | Input positive | Output positive | ---- | Output negative | ---- |
