48V to 5V 10W 2000mA DC to DC Isolation Voltage Power Module Converter VRB4805LD-10WR3
Visitor2454
Price$4.28
1. Ultra wide range input (2:1), output 10W
2. Conversion efficiency 86%(Typ)
4. Ultra low standby power consumption: 0.3W (typical)
5. Ultra fast start: 100mS (typical)
Related input voltage | 48 | Vdc | |
Input voltage range | 36-72 | Vdc | |
Maximum input current | ≤0.4 | A | |
Reflection ripple current | 30 | mA | DC12V rated input voltage series |
Impulse voltage | ≤100 | Vdc | |
Starting voltage | 36 | Vdc | |
Start-up delay | 100 | ms | Rated input voltage and constant resistance load |
Output Characteristics(5V/2000mA)
Short-time maximum output current | ≥2200 | mA | |
Rated output current | 2000 | mA | |
Load regulation | ±1 | % | |
Transfer efficiency | Vin=48Vdc, output full load 86 | % | |
MOV1/Varistor | Protest the circuit from damage when the module is abnormal | 14D333K |
LDM1/Common mode inductance | EMI Filtering | Inductance: 2mH |
CO,C1 Ceramic capacitors | Filter capacitor | 1uF/100V |
E1,E2 Electrolytic capacitor | Filter capacitor | 470uF/100V |
1 | 2 | 3 | 4 | 5 | 6 |
Input negative | Input positive | Output positive | ---- | Output negative | ---- |
