24V to 5V 10W 2000mA DC to DC Isolation Voltage 1500VDC Power Module Converter VRB2405LD-10WR3
Visitor2275
Price$3.99
1. Wide input voltage range 2:1, isolated regulated output 5W
3. Transfer efficiency up to 86%
4. Quick Start:100mS(Typ)
Input voltage range(fully loaded/unloaded) | 12VDC Input Series | 3.3V | - | 714/25 | 733/42 | |
5.0V | - | 1067/25 | 1096/42 | |||
12.0V | - | 845/25 | 867/42 | |||
15.0V | - | 1003/25 | 1028/42 | mA | ||
24.0V | - | 911/25 | 1015/42 | |||
24VDC Input Series | 3.3V | - | 357/13 | 366/21 | ||
5.0V | - | 533/13 | 548/21 | |||
12.0V | - | 423/13 | 434/21 | |||
15.0V | - | 502/13 | 514/21 | |||
24.0V | - | 455/13 | 508/21 | |||
48VDC Input Series | 3.3V | - | 179/7 | 183/11 | ||
5.0V | - | 267/7 | 274/11 | |||
12.0V | - | 212/7 | 217/11 | |||
15.0V | - | 251/7 | 257/11 | |||
24.0V | - | 228/7 | 148/11 | |||
110VDC Input Series | 3.3V | - | 78/3 | 80/2 | ||
5.0V | - | 116/3 | 119/5 | |||
12.0V | - | 109/3 | 111/5 | |||
15.0V | - | 209/3 | 214/5 | |||
24.0V | - | 105/3 | 107/5 | |||
Reflected Ripple Current | 12VDC Input Series | -- | 60 | -- | mA | |
24VDC Input Series | -- | 40 | -- | |||
48VDC Input Series | -- | 30 | -- | |||
Impulse voltage (Isec.max) | 12VDC Input Series | -0.7 | -- | 30 | VDC | |
24VDC Input Series | -0.7 | -- | 50 | |||
Start voltage | 12VDC nominal input series, nominal input voltage | - | - | 9 | ||
24VDC nominal input series, nominal input voltage | - | - | 18 | |||
48VDC nominal input series, nominal input voltage | - | - | 36 | |||
110VDC nominal input series, nominal input voltage | - | - | 72 | |||
Input undervoltage protection | 24VDC nominal input series, nominal input voltage | - | - | - | ||
48VDC nominal input series, nominal input voltage | - | - | - | |||
110VDC nominal input series, nominal input voltage | - | 100 | - | |||
