24V to 15V 666mA 10W DC to DC 91% transfer efficiency input power supply module converter URB2415YMD-10WR3
Visitor2335
Price$3.92
1. Ultra wide range input (4:1), output 10W
Maximum input current | ≤1.3 | A | |
Reflection ripple current | 40 | mA | DC12V rated input voltage series |
Input undervoltage protection | 5.5 | Vdc | |
Output Characteristics(15V/660mA)
No load rated output voltage | 15V±2% | Vdc | |
Short-time maximum output current | ≥760 | mA | |
Rated output current | 660 | mA | |
Load regulation | ±1 | % | |
Transfer efficiency | Vin=24Vdc, output full load 91 | % | |
Output over-voltage protection | Outputting 110-160% the maximum voltage | Vdc | |
MOV1/Varistor | Protest the circuit from damage when the module is abnormal | 14D561K |
LDM1/Common mode inductance | EMI Filtering | Inductance: 10-30mH |
LDM2/Differential mode inductance | EMI filtering | 10-68uH |
1 | 2 | 3 | 4 | 5 | 6 |
Input negative | Input positive | Output positive | ---- | Output negative | ---- |
