24V to 5V 1W 200mA DC to DC 88% transfer input power supply module B2405S-1WR3
Visitor1416
Price$1.03
2. transfer efficiency 88%(Typ)
10. Adopts high quality environmental protection, waterproof and heat conducting adhesive for filling and sealing, moisture-proof and vibration proof, meeting the waterproof and dustproof IP65 standard
Items | Working conditions | Unit | Notes |
Input voltage range | 21.6-24.6 | Vdc | |
Maximum input current | ≤0.2 | A | |
Reflection ripple current | 15 | mA | DC12V rated input voltage series |
Impulse voltage | ≤30 | Vdc | |
Starting voltage | 21.6 | Vdc | |
Input under voltage protection | --- | Vdc | |
Start delay time | --- | Vdc | Reted input voltage and constant resistance load |
Input filter type | Capacitive filtering | ||
Hot plug | Non-support |
Notes: test at room temperature
Output Characteristics(5V/200mA)
Items | Technical parameters | Unit | Notes |
No-load rated output voltageVdcVdc | 5V±15% | Vdc | |
Short time maximum output current | ≥220 | mA | |
Rated output current | 200 | mA | |
Voltage regulation | ±1.5 | % | |
Load regulation | ±12 | % | |
Conversion efficiency | Vin=24Vdc, Output full load 80 | % | |
Output ripple and noise(m Vp-p) | ≤100 Pure resistive load, 20MHz bandwith, peak to peak value | mV | |
Output over-voltage protection | Output 110-160% of the maximum voltage | Vdc | |
Insulation voltage | Input-output, test time 1 minute, leakage current less than 1mA/1500V | ||
Insulation resistance | Input-output, insulation voltage 500VDC/1000MΩ | MΩ | |
Isolated capacitor | Input-output,100KHz/0.1V 20pF |
1. Due to limited space, the above is only a list of typical products. If you need products outside the list, please contact our sales department.
2. The maximum capacitive load indicates the maximum capacitive load that + Vo or -Vo can connect to. If it exceeds this value, the product will not start normally.
