  4. AC DC 10W
  5. Ultra small AC/DC 10W 220V to 3.3V/5V/9V/12V/15V/24V step down mini power switch power converter module HLK-10M05TL/10M12TL/10M24TL
    $1.62
产品型号-3 拷贝
 For the specific model you need, please leave your message and we will contact you ASAP. Thank you inadvance.
Working Temerature-25—+60 ℃
Storage temperature-40—+80 ℃
Relative humidity5—95 %
Altitude≤2000 m
Rated input voltage100-240Vac
Input inrush current ≤10A
Input low start≤50mS
Short term maximum output current≥2600mA
Rated output current2000mA
Voltage regulation rate±0.1%
Load regulation  rate±0.5%
Output over-current protection Output maximum load110-150% A
Ripple/Noise≤100mVp-p(Typ:50)
No-load rated output voltage12.0±0.1Vdc
Full-load rated output voltage12.0±0.1Vdc
Rated output current830mA
