  4. DC DC 30W
  5. URA4805LMD-30WR3 URA4803/4812/4815/4824LMD-30WR3 DC DC isolated Voltage Regulating Power Supply Converter Module
    $9.75
URAXX_LMD-30WR3 Series Mode list 拷贝 2
1. Wide input voltage range 4:1, isolated regulated output 30W
4. Quick Start:1mS(Typ)
Ripple & Noise50/80(max)
Mvp-p
ItemWorking conditions
Min.Typ.Max.Unit
Input voltage range(fully loaded/unloaded)24VDC Input Series3.3V-782/208800/30mA
5V-926/259947/35
12V-926/1.5947/2
15V-916/1.5937/2
24V-916/1.5937/2
±5V-968/25992/35
±12V-926/1.5947/2
±15V-926/1.5937/2
±24V-936/2957/2
48VDC Input Series3.3V-391/10400/15
5V-463/12474/18
12V-458/1469/1.5
15V-458/1469/1.5
24V-458/1469/1.5
±5V-484/1496/1.5
±12V-458/1496/1.5
±15V-458/1496/1.5
±24V-468/2478/2
110VDC Input Series3.3V-173/1177/2
5V-206/1213/2
12V-202/0.3206/0.5
15V-200/0.3204/0.5
24V-200/0.3204/0.5
±5V-211/0.3216/0.5
±12V-202/0.3206/0.5
±15V-200/0.3204/0.5
±24V-200/0.3204/0.5
Reflected Ripple CurrentNominal Input Series--4--mA
Impulse voltage  (Isec.max)24VDC Input Series-0.7--50
48VDC Input Series-0.7--100
110VDC Input Series-0.7--180
Start voltage24VDC nominal input series, nominal input voltage--9
Input undervoltage protection24VDC nominal input series, nominal input voltage5.58-
110VDC nominal input series, nominal input voltage3034-
PI filter type
Output loadload percentage0%-100%0%-100%
-±1.0%±2.0%-±2.0%±3.0%
±2.0%±0.5%-±1.5%±2.0%
Load adjustment rate
20%~100% rate
load, balanced
±0.5%
±1.0%-±4.0%±5.0%
