URB2412XLD-30WR3 URB2405XLD/URB2424XLD DC isolated power module DC-DC voltage regulation and step-down single output
Visitor1060
Price$7.20
UR(A)B_XLD-30WR3 series product output power is 30W,4:1 wide voltage input range,efficiency up to 91%,conversional isolation volatge of 1500VDC,allowable operating temperature is -40℃to+85℃, with input under-voltage protection, output over-voltage, over-current,short-circuit protection function, bare metal meets CISPR32/EN55032CLASSA , widely used in medical, industrial control, electri power, instrumentation,communication, railway and other fields.
Wide input voltage range(4:1),Output 30W
Conversion efficiency91%(Typ)
Isolation voltage 1500Vdc
Ultra low power consumption:0.036W(Typ)
Fast startup:1ms(Typ)
Working temperature range:-40°C~+85℃
Input undervoltage , output short circuit , overcurrent,overvolatge protection
Metal case,low output ripple
International standard pins,PCB board in-line
Vibrate | 10-55Hz, 10G, 30 Min. along X, Y and Z |
Project name | Working conditions | Min. | Typ. | Max. | Unit | |
Input current(full load/ no-load) | 24VDC nominal input series, nominal input voltage | 3.3V | - | 1106/5 | 1132/15 | mA |
5V | - | 1420/5 | 1453/15 | |||
12V | - | 1388/1.5 | 1420/2 | |||
15V | - | 1373/1.5 | 1404/2 | |||
24V | - | 1373/1.5 | 1404/2 | |||
±5V | - | 1436/5 | 1470/15 | |||
±12V | - | 1388/1.5 | 1420/2 | |||
±15V | - | 1373/1.5 | 1404/2 | |||
±24V | - | 1373/1.5 | 1404/2 | |||
48VDC nominal input series, nominal input voltage | 3.3V | - | 553/0.8 | 566/1 | ||
5V | - | 710/0.8 | 726/1 | |||
12V | - | 694/0.8 | 710/1 | |||
15V | - | 687/0.8 | 702/1 | |||
24V | - | 687/0.8 | 702/1 | |||
±5V | - | 710/0.8 | 726/1 | |||
±12V | - | 694/0.8 | 710/1 | |||
±15V | - | 687/0.8 | 702/1 | |||
±24V | - | 687/0.8 | 702/1 | |||
110VDC nominal input series, nominal input voltage | 3.3V | - | 687/0.8 | 702/1 | ||
5V | - | 310/1 | 317/2 | |||
12V | - | 303/0.3 | 309/0.5 | |||
15V | - | 299/0.3 | 309/0.5 | |||
24V | - | 299/0.3 | 306/0.5 | |||
±5V | - | 310/1 | 317/2 | |||
±12V | - | 303/0.3 | 309/0.5 | |||
±15V | - | 299/0.3 | 309/0.5 | |||
±24V | - | 299/0.3 | 309/0.5 | |||
Reflected ripple current | nominal input voltage | - | 40 | - | mA | |
Impulse Voltage( Isec.max) | 24VDC nominal input series | -0.7 | - | 50 | VDC | |
48VDC nominal input series | -0.7 | - | 100 | |||
110VDC nominal input series | -0.7 | - | 180 | |||
Start Voltage | 24VDC nominal input series | - | - | 9 | ||
48VDC nominal input series | - | - | 18 | |||
110VDC nominal input series | - | - | 40 | |||
Under voltage protect | 24VDC nominal input series | 5.5 | 6.5 | - | ||
48VDC nominal input series | 12 | 15.5 | - | |||
110VDC nominal input series | 30 | 34 | - | |||
Start time | Nominal input voltage and constant resistance load | - | 1 | - | ms |
Component No. | 24V Input Product | 48V Input Product | 110V Input Product |
FMSE Fuse | Access the corresponding fuse accrding to customer needs | ||
MOV/Varistor | 14D560K | 14D101K | 14D201K |
LDM1/Common mode inductance | 10mH | 15mH | 30mH |
CO,C1 Ceramic capacitors | 100μF/50V | 100μF/100V | 100μF/200V |
E1,E2 Electrolytic capacitor | 1μF/50V | 1μF/100V | 0.47μF/250V |
LDM2/Differential mode inductance | 10μH | 15μH | 68μH |
