  4. AC DC 22W
  5. AC-DC 22W series 220V to 5V power supply stable output isolated power converter module HLK-22M05Z
    $2.62
产品型号-3 拷贝
The HLK-22M05Z bare board power module is a small-sized, high-efficiency module power supply designed by Hi-link Electronics for customers. Having global input voltage
Advantages include range, low temperature rise, low power consumption, high efficiency, high reliability, and high safety isolation. Widely used in smart homes, automation control, and communication in industries such as telecommunications equipment and instrumentation.
Product Specifications
  • Ultra thin, compact, and small volume in the industry
  • Global universal input voltage (100~240Vac)
  • Low power consumption, green environmental protection, no-load loss<0.5W
  • Low ripple and low noise
  • Good output short-circuit and overcurrent protection and self recovery
  • Input/output isolation withstand voltage 4000Vac, surge resistance 4KV
  • 100% full load aging and testing
  • High reliability and long-life design, with continuous working time greater than 70000 hours
  • Meet the circuit requirements of UL and CE; Product design meets EMC and safety testing requirements
  • Adopting high-quality environmental protection, moisture resistance, and vibration resistance to meet various requirements and standards
  • Economic solutions with high cost-effectiveness
  • Can work without external circuits
Environment condition
Item nametechnical indexUnitRemark
Working Temerature-25—+60
Storage Temerature-40—+80
Thermal methodsnatual cooling
Atmospheric pressure80—106Kpa
Altitude≤2000m
Vibration coefficient
Input Features(test at room temperature)
Rated input voltage100-240Vac
Input vlotage range90-264Vac
or 120-350Vdc
The maximum input CURRENT≤0.7A
Input inrush current ≤50A
Input low start≤3S
No-load rated output voltage5.0±0.1VdcVdc
Full-load rated output voltage5.0±0.2VdcVdc
Short term maximum output current6000mAmA
Rated output current4500mAmA
Voltage regulation rate≤±2
Load regulation  rate≤±5%
Input low voltage efficiency
Vin=115Vac, Output full load ≥ 83
Input high voltage efficiency
Vin=230Vac, Output full load ≥ 85%
Output ripple and noise
≤120
Rated input voltage, output at full load. Using a 20MHz bandwidth oscilloscope,
Test the load end with 10uF and 0.1uF capacitors.
mV
Switching on/off overshoot amplitude(Rated input voltage, output with 10% load) ≤5%VO%VO
Output overcurrent protectionOutput 110-140% of maximum loadA
OUtput Short Circuit Protection
Short circuit directly during normal output, and automatically resume normal operation after the short circuit is removed
Do not damage the entire machine
dimension
Dimensional error:
1. Length, width, height, and pin spacing error ± 1mm
2. Pin length error ± 1mm
3. Pin diameter error -0.2mm
Unit: Millimeters
