  4. DC DC 1W
  5. IA0505S-1WR3 IA0503/IA0509/IA0512/IA0515/IA0524S-1W DC-DC isolated step down power supply module with short-circuit protection
    $1.18
IA_S Series Mode list 拷贝
Product Features:
  • 5Pin SIP international standard pin
  • Isolation voltage: 1500VDC
  • Low static current and high conversion efficiency
  • Low ripple coefficient and low noise
  • Working environment temperature: -40 ℃~+85 ℃
  • MTBF ≥ 3.5 million hours (3500000 Hrs)
  • Output short circuit protection: sustainable short circuit protection, automatic recovery
  • Built in soft start technology
  • Special specification products can be designed according to customer needs
Input characteristic:
Item
Working ConditionsMin.Typ.Max.Unit
Input voltage range5VDC input series--519/5--/10Vdc
12VDC input series--208/3--/5
24VDC input series--102/1--/2
Reflected ripple current
--15--
Impulse Voltage
5VDC input series-0.7--9Vdc
12VDC input series-0.7--18
24VDC input series-0.7--30
Input fliter typle
Capacitive filtering
Hot plug
*This series of modules does not have input anti reverse connection function. It is strictly prohibited to input positive and negative reverse connections, otherwise it will cause irreversible damage to the module
Output characteristic:
ItemWorking and testing conditionMin.Typ.Max.Unit
----±3.0%
Linear adjustment rateInput voltage variation ±5%----±0.25%
Load adjustment rate10%~100% load--+1+2%
----±0.03%/℃
General characteristic:
Item
Working conditionMin.Typ.Max.Unit
Insulation voltageInput output, test time of 1 minute, leakage current less than 1mA1500----VDC
Insulation resistance Input output, insulation voltage 500VDC 1000-M Ω1000----MΩ
Isolation capacitorInput output, 100KHz/0.1V --40-- pF--20--pF
Working temperature Use reference temperature derating curve chart-40--+85
Storage temperature
-40--+125
Temperature rise of the casing during operation
--25--
Storage humidityNo condensation5--95%RH
Pin resistance to welding temperatureWelding point distance from the shell 1.5mm, 10 seconds----+300
Switching frequency Full load, nominal voltage input--100--KHz
Shock
10-55Hz, 10G, 30 Min. along X, Y and Z
Shell material
Black flame retardant and heat-resistant plastic (UL94V-0)
Minimum time between failuresMIL-HDBK-217F@25℃3.5X10 6----Hrs
pin description 拷贝
For more detail, please feel free to contact us.
