F0505S-1WR3/F0503S/F0512S/F0515S/F0524S-1WR3 DC to DC 5V to 3.3V/5V/9V/12V/15V/24V 1W power module/converter passed UL/CE/FCC certifications
Visitor466
Price$0.48
2. Isolation voltage 3000VDC
Ripple & Noise | 30/80(max) | Mvp-p |
Input current (full load/no load) | 3.3VDC Input Series | -- | 378/8 | --/15 | m'A |
5VDC Input Series | -- | 227/5 | --/10 | ||
12VDC Input Series | -- | 93/2 | --/5 | ||
15VDC Input Series | -- | 74/2 | --/4 | ||
24VDC Input Series | -- | 46/1 | --/2 | ||
Impulse voltage | 3.3VDC Input Series | -0.7 | -- | 5 | VDC |
12VDC Input Series | -0.7 | -- | 18 | ||
Output Voltage Accuracy | See Error Envelope Curve | -- | -- | ±15.0 | % | |
Linear adjustment rate | Input voltage variation ±1% | 3.3V Input | -- | -- | ±1.5 | % |
others | -- | -- | ±1.2 | % | ||
Load adjustment rate | 10%~100% load | 3.3VDC Output | -- | 18 | -- | % |
5VDC Output | -- | 12 | -- | % | ||
9VDC Output | -- | 8 | -- | % | ||
12VDC Output | -- | 7 | -- | % | ||
15VDC Output | -- | 6 | -- | % | ||
24VDC Output | -- | 5 | -- | % | ||
Output short circuit protection | Continuous short circuit protection, automatic recovery | -- | ||||
1. Routine application:
If it is required to further reduce the input and output ripple, a capacitive filter network can be connected at the input and output terminals, and the application circuit is shown in Figure 1.
However, attention should be paid to the selection of appropriate filtering capacitors. If the capacitor is too large, it is likely to cause startup problems. For each output, the recommended capacitive load value is shown in Table 1 under the condition of safe and reliable operation.
2.EMI typical application circuit
Cout Capacitance | Filter capacitor | Refer to usual application |
3. Output Load Requirements
Product appearance size and pin definition, suggested printing layout
*Note: If the definition of each pin of the power module is inconsistent with the selection manual, the label on the physical label shall prevail.
