VRB2405YMD-6WR3 Power Converter VRB2403/VRB2412/VRB2415/VRB2424YMD-6WR3 DC-DC isolated stable voltage output power supply module
Visitor1326
Price$2.75
1. Wide input voltage range 2:1, isolated regulated output 6W
4. Quick Start:100mS(Typ)
Input voltage range(fully loaded/unloaded) | 12VDC Input Series | 3.3V | - | 428/25 | 440/30 | mA |
others | - | 641/25 | 658/30 | |||
24VDC Input Series | 3.3V | - | 214/13 | 220/15 | ||
others | - | 320/13 | 329/15 | |||
48VDC Input Series | 3.3V | - | 107/7 | 110/8 | ||
others | - | 161 | 164/8 | |||
110VDC Input Series | 3.3V | - | 47/3 | 48/4 | ||
others | - | 70/3 | 72/4 | |||
Reflected Ripple Current | 12VDC Input Series | -- | - | -- | mA | |
24VDC Input Series | -- | - | -- | |||
48VDC Input Series | -- | - | -- | |||
Impulse voltage (Isec.max) | 12VDC Input Series | -0.7 | -- | 30 | VDC | |
24VDC Input Series | -0.7 | -- | 50 | |||
Start voltage | 12VDC nominal input series, nominal input voltage | - | - | 9 | ||
24VDC nominal input series, nominal input voltage | - | - | 18 | |||
48VDC nominal input series, nominal input voltage | - | - | 36 | |||
110VDC nominal input series, nominal input voltage | - | - | 72 | |||
Input undervoltage protection | 24VDC nominal input series, nominal input voltage | 5.5 | 6.5 | - | ||
110VDC nominal input series, nominal input voltage | 32 | 36 | - | |||
Output voltage regulation | Input voltage range | - | No adjustment end | - | - | No adjustment end | - | |
