  4. DC DC 6W
  5. URB2405S-6WR3 URB2424S/03S/09S/12S/15S-6WR3 24V to 3.3V/9V/12V/15V/24V 5DC DC isolated stablized voltage power supply module
    $2.60
URB_S-6WR3 Series Mode list 拷贝
4. Low ripple noise
7. No-load power consumption less than  0.12W
Ripple & Noise50/130(max)
Mvp-p
ItemWorking conditions
Min.Typ.Max.Unit
Input voltage range(fully loaded/unloaded)24VDC Input Series3.3V output-238/5245/12mA
5V output-305/5313/12
others-305/5313/12
48VDC Input Series3.3V output-119/3123/6
5V output-152/3162/6
others
152/3162/6
Reflected Ripple Current-
--50--mA
Impulse voltage  (Isec.max)12VDC Input Series-0.7--50VDC
24VDC Input Series-0.7--100
Input undervoltage protection12VDC nominal input series, nominal input voltage5.57.0-
24VDC nominal input series, nominal input voltage1316.0-
Project nameWorking and testing condition
Min.Typ.Max.Unit
Output voltage accuracy5%~100% no-load, input voltage range3.3V/5V output--±3.0±5.0%
others--±1.0±2.0%
Line Regulation
--±0.5±1.0%
Load Regulation5%~100% load
--±0.5±1.5%
Transient Recovery Time25% load step change
--±5±8mS
Transient response bias
--±3±5%
Ripple&NoisePure resistive load, 20MHz bandwidth, peak to peak value
--50130mVp-p
Temperature drift coefficientfull load
--±0.02±0.03%/°C
Sustainable, self-healing
Note:The testing method for ripple and noise is the twisted pair testing method.
pin descrption 拷贝
EMC diagram
