  4. 60G radar sensor module
  5. Hi-link 60G radar sensor module test board LD6001 intelligent sensing detection of human body area position, quantity statistics, and walking trajectory
    $28.35
HLK-LD6001-1 拷贝
HLK-LD2420: https://drive.google.com/drive/folders/1IggDH6ejNSOs8EklQbAXcqUI7KENSZLt?usp=sharing
HLK-LD2451: https://drive.google.com/drive/folders/1Xl7lnvCAQHD2xjOfU_lpxdr0GGXO0-F6?usp=sharing
HLK-LD6001: https://drive.google.com/file/d/1lJ8Q1gavV_uBjRdbdkvXneLqPl5dG83O/view?usp=sharing
HLK-LD6001A: https://drive.google.com/file/d/1FmuCOF4Ao6_-ismF7j4xBd8VGdTdG-GJ/view?usp=sharing
HLK-LD6001C: https://drive.google.com/file/d/1u00TH9nXYE_9Jml9VwZ4z0sUKFog7o3K/view?usp=sharing
HLK-LD6002C: https://drive.google.com/drive/folders/1UFBTpL7mLjvzcOgDNnifWcXyOEQX2Cx5?usp=sharing
HLK-LD6002B: https://drive.google.com/drive/folders/1ug-oR3rV8ndN-lEZMgYn8a-KIOFFdn4V?usp=sharing
HLK-LD6002: https://drive.google.com/drive/folders/1oMJYYOvhXx9uJD9SCkCsjMzLqdOg7AqR?usp=sharing
The LD6001 module is a 4T3R (four channel transmitter, three channel receiver) fully integrated 60GHz millimeter wave radar module. Can be used to detect the location and quantity of human body areas (up to 8 people), walking trajectories, etc.
Product parameters
ParametersValueUnitRemark
Working frequency range60GHz
Sending voltage12dBm
Modulation TypeFMCW/
Frequency modulated continuous wave
Sweep frequency broadband4GHz
Horizontal width of antenna beam±60°
Antenna beam elevation width±30°
Detect the farthest distance
8m
Working voltage 5V
Average power consumption1.1W
Working teperature-15~70
Dimension60*30mm
Start time3s
Installation requirement
Install the module on a vertical wall with a height of 2.2 meters, and tilt the front of the module (with the antenna facing upwards) at an angle of 10 degrees. It is generally recommended to install it according to this method for the most ideal effect, but it can also be installed slightly higher or the angle can be adjusted slightly as needed. The actual test effect shall prevail.
The schematic diagram of the target installation effect, as well as the distance, horizontal angle, and pitch angle, are shown in the following figure:
LD6001 pic 拷贝
Please feel free to contact us for more detail.
