  4. DC DC 6W
  5. VRA4812YMD-6WR3 Hi-link dc-dc 6W VRA4803/VRA4805/VRA4815/VRA4824YMD-6WR3 voltage stablization dual output power converter module
    $3.28
VRA_YMD-6W Series Mode list 拷贝
1. Wide input voltage range 2:1, isolated regulated output 6W
4. Quick Start:100mS(Typ)
Ripple & Noise50/80(max)
Mvp-p
ItemWorking conditions
Min.Typ.Max.Unit
Input voltage range(fully loaded/unloaded)12VDC Input Series3.3V-428/25440/30mA
others-641/25658/30
24VDC Input Series3.3V-214/13220/15
others-320/13329/15
48VDC Input Series3.3V-107/7110/8
others-161164/8
110VDC Input Series3.3V-47/348/4
others-70/372/4
Reflected Ripple Current12VDC Input Series-----mA
24VDC Input Series-----
48VDC Input Series-----
110VDC Input Series--20--
Impulse voltage  (Isec.max)12VDC Input Series-0.7--30VDC
24VDC Input Series-0.7--50
48VDC Input Series-0.7--100
110VDC Input Series-0.7--200
110VDC nominal input series, nominal input voltage--72
Input undervoltage protection24VDC nominal input series, nominal input voltage---
48VDC nominal input series, nominal input voltage---
110VDC nominal input series, nominal input voltage---
-±1.0%±2.0%-±2.0%±3.0%
±0.2%±0.5%-±1.5%±2.0%
Load adjustment rate
20%~100% rate
load, balanced
±0.5%
±1.0%-±4.0%±5.0%
diamension 拷贝
