AC to DC 3W 3.3V/5V/9V/12V/15V/24V Step Down Mini Power Supply Converter Switch Power Module With EMC HLK-3M05C/3M12C/3M15C/3M24C
Visitor2318
Price$1.72
Please leave you message for the specific model you need, we will contact you for conforming.Thank you inadvance.
Working Temerature | -25—+60 ℃ |
Storage temperature | -40—+80 ℃ |
Relative humidity | 5—95 % |
Thermal methods | Natural cooling |
Atmospheric pressure | 80—106 Kpa |
Altitude | ≤2000 m |
Vibration coefficient | 10~500Hz,2G10min./1cycle, 60min.each along X,Y,Z axes. Meets secondary road transportation requirements |
Rated input voltage | 100-240Vac |
Input vlotage range | 85-265VAC/120-350VDC |
The maximum input CURRENT | ≤0.2A |
Input inrush current | ≤10A |
Input low start | ≤200mS |
Long-term reliablity | MTBF≥100000H |
External fuse recommended | 1A/250Vac or 10Ω wire wound resistance, Slow blow |
Output Features 3.3V
No-load rated output voltage | 3.3±0.1Vdc |
Full-load rated output voltage | 3.3±0.1Vdc |
Short term maximum output current | ≥1400mA |
Rated output current | 1000mA |
Voltage regulation rate | ±0.1% |
Load regulation rate | ±0.5% |
Switching on/off overshoot amplitude | (Rated input voltage, output with 10% load) ≤5%VO |
Ripple/Noise | ≤50mV |
Output Features 5V
No-load rated output voltage | 5.0±0.1Vdc |
Full-load rated output voltage | 5.0±0.2Vdc |
Short term maximum output current | ≥1200mA |
Rated output current | 600mA |
Voltage regulation rate | ±0.2% |
