HLK-10M24 AC/DC 24v 10w Step Down mini Power Supply Module Converter Intelligent household switch power module
Visitor3872
Price$1.78
5W: https://drive.google.com/drive/folders/13pTx02uL4moskJ-PQsBYFytdq2pPt2mN
Working Temerature -25—+60 ℃
Storage temperature -40—+80 ℃
Relative humidity 5—95 %
Altitude ≤2000 m
The maximum input CURRENT ≤0.3A
Input inrush current ≤34A
Input low start ≤50mS
Full-load rated output voltage 24±0.2%
Load regulation ±0.5%
Ripple/Noise ≤70mVp-p(Typ:50)
Meet UL/CE requirements
mensional error:
1. Length, width, height and pin pitch error ± 8%
2. Pin length error ± 1mm
3. Pin diameter error +-0.2mm
